engine noise with my polk C400.4 amp
docsnead
I installed a pioneer DEH-P5800MP head unit and put db6750 in the front doors of my 02 avalanche.
Next I bought a C400.4 Carbon Series 4/3/2 channel Amplifier. When I first put it in I was getting engine noise through the speakers. So I thought it was maybe the ground wire and I unbolted it and used gas to clean the undercoat of the chassis then used sand paper and rebolted the ground. That didn't work so I started checking the RCA wires and when I would unpluged the front speaker RCA cables the noise would stop so I switch rca cables and unplugged the cable I thought was bad. I proceeded to ajusted the amp using only db6750 in the front doors man did that sound loud and clear.
Today I put a new RCA cable on the rear speakers and Installed a brand new set of mmc6500 momo in the rear doors and when I went to test them my engine noise came back. Frustrated I put a jumper wire from the body ground to my chassis ground and that did not work either. If I unplug the rear RCA the noise goes away.
what should I do next ?
Thanks in advance ,
Keith
Thanks in advance ,
Keith
Ht:
Yamaha rx v2700
Adcom GFA-7707
Lsi 15 frontL/R
lc265i center
lc265i side L/R
lc265i back L/R
PSW 1000
samsung 710AE projector
Yamaha rx v2700
Adcom GFA-7707
Lsi 15 frontL/R
lc265i center
lc265i side L/R
lc265i back L/R
PSW 1000
Post edited by docsnead on
Hi and welcome to the Forum!
If you'll scroll down the page a little, you'll see a "Car Audio and Electronics" sub-forum. You'll have better luck if you post your question in there. It's mostly home-audio enthusiasts in this section.
Jason -
Thanks Jason.
KeithHt:
Yamaha rx v2700
Adcom GFA-7707
Lsi 15 frontL/R
lc265i center
lc265i side L/R
lc265i back L/R
PSW 1000
samsung 710AE projector -
Try regrounding the headunit to a different location, particularly if only using the OEM ground on the factory harness.-Eric
-Polk Audio -
Ok Eric i will give a try.
ThanksHt:
Yamaha rx v2700
Adcom GFA-7707
Lsi 15 frontL/R
lc265i center
lc265i side L/R
lc265i back L/R
PSW 1000
Thanks everyone I rerouted rca's and it fix the problem.
KeithHt:
Yamaha rx v2700
Adcom GFA-7707
Lsi 15 frontL/R
lc265i center
lc265i side L/R
lc265i back L/R
PSW 1000
