LS-25 Sub out of control
Musophile
Musophile Posts: 89
edited May 2006 in Troubleshooting
Not quite sure how to diagnose this one. My sub on my right LSI-25 is trying to output huge amounts of base when there isn't such a signal. I've turned off the sub now and the mids and tweets play fine. The sub on the left LSI-25 is playing fine. Is there something I should be looking at?
James
Home Theater In Progress
Samsung 4272
Denon 3910 Universal Player
Anthem AVM-20
Anthem Statement A5
Fronts LSI-25
Center LSI-C
Surround LSI-FX
Getting closer to complete!:D
Post edited by Musophile on
  • Eric W
    Eric W Posts: 556
    edited May 2006
    Hi, what kind of sound is it? Is it a hum or buzz? Or is it another sound?
    Also, how do you have the speakers hooked up signal wise (speaker wire, or speaker wire + line level?).
    -Eric
    -Polk Audio
  • Musophile
    Musophile Posts: 89
    edited May 2006
    It's just a boom boom boom sound that's very deep coming from the subwoofer. There's no variation in tone. It's just the same deep boom.
    It's hooked up with speaker wire and LE input.
    Thanks for responding Eric.
    Samsung 4272
    Anthem AVM-20
    Anthem Statement A5
    Fronts LSI-25
    Center LSI-C
    Surround LSI-FX
  • pmckeealaska
    pmckeealaska Posts: 808
    edited May 2006
    Have you tried messing with the subwoofer cables? I have the same problem when the cable from the LFE was loose.....might be a simple solution
    Music and Movie Rig
    Samsung 40" HDTV 1080p
    LSi25 Front Speakers
    LSiC Center Channel
    LSiFX Surrounds
    Rotel RB 1080 2-Channel Amp
    NAD T763 Reciever
    Denon DVD 2900 Universal Player
    Audiosource 10 Band Digital Equalizer
    Audioquest CV-8 speaker cables
    Audioquest Sub-X subwoofer cables
    Audioquest King Cobra Interconnects
    Monster AVS 2000 Voltage Stabilizer
    Playstation 3 120GB Slim
  • Musophile
    Musophile Posts: 89
    edited May 2006
    I unplugged the LFE cable from the speaker this morning and it didn't help. I'll try from the pre-pro end.
    Samsung 4272
    Anthem AVM-20
    Anthem Statement A5
    Fronts LSI-25
    Center LSI-C
    Surround LSI-FX
