is center Csi25 mountable?
Those who has Csi25 center speaker, can you tell me if it's wall mountable like it has hole behind it so i can slide it down using a screw (similar to R15s)? i plan to put either on top or bottom of my tv.
Post edited by jon2k2 on
No keyhole slot for wall mounting. The port is in the back so you wouldn't want to mount it flush on a wall anyway.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
so how will you place the center speaker? i have a tv hung on a wall and would like to place it underneath the tv. so make a base support on the wall and just place it on top? is there like a wall mount for center speaker usually?
For placing underneath a flat panel TV, center channel speaker stands are available from various manufacturers. try a google search for speaker stands. If you have an entertainment center or component rack under the TV you could place it there as well.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
What do you do if you have a TV stand that is taken up with equipment and no where to go with the center channel. I have a Sony 55" lcd rear projection and am looking for a place to put my center. Do they make something that I can go on top of the TV with??
