What a bad idea....
noimposse
noimposse Posts: 264
edited May 2006 in Troubleshooting
So I got home from school yesturday and I start setting up the electronics. I just throw together the reciever and a single sony speaker to listen to some tunes while I sort cables and whatnot and all was well.
I got just about everything done and go to hook up speaker wire for the other channels on the reciver, forgetting I was already listening to music. I sure you know what happened next....
Damn thing went into protection mode, so I turn it off, wait a few minutes and turn it back on....works alright. So I pop in the new tool cd (still only running the right channel with a speaker, right is on but has nothing attached)...everything is ok so far. So I turn it up a bit.....****, protection mode again.
I turned off the left channel and everything is good. I kept the left channel on and just took out the speaker wire and everything is still good. So I pretty much just narrowed it down to an issue with only that channel...but I just need to know if there is something I can do to fix this, because I have 0 money for quite a while. This whole college thing takes way too much money.
Im running a Kenwood vr-705 with rti4's if that helps any. Yes I know the avr is awful, but its what I have until I can get some money.
Anyway, if there is something I can do, please let me know. Thanks.
Ghetto Rig
Power: HK AVR245.
Screen: LG 24" 1080p.
Speaks: Rti4.
Source: PC. PS3. Xbox360.
Cables: BlueJeans. Monoprice.
Post edited by noimposse on
  • ledhed
    ledhed Posts: 1,088
    edited May 2006
    Make sure no speaker wire is touching i.e no single strands peeking out of the + and touching the - or any connection between the left and right chennels. That will turn the avr into protection mode.
    God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
  • noimposse
    edited May 2006
    Thanks. I checked and there were no strands that I could see touching.
    It does physically work, it just cant be turned up loud enough. For example at -50db is fine, I will slowly turn it up from there and it is fine until it gets to about -38db then it clicks off. Usually the same spot every time.
    Ghetto Rig
    Power: HK AVR245.
    Speaks: Rti4.
  • danger boy
    danger boy Posts: 15,722
    edited May 2006
    unplug any speaker or speakers you have connected. then do the same thing .. turn the volume up. see what happens.. if it goes into protect mode again.. there is something internal that is causing it to go into protect.
    if not. then it may be your sony speaker or speaker wire.. in which case. replace both..
    PolkFest 2012, who's going>?
  • noimposse
    edited May 2006
    Wow. I switched out the cable with the one that was hooked to the functioning channel and all the issues went away. I just trashed the old wire and got a new one real quick.
    Don't really know why that would happen, but it worked so I'm not going to question it much. Thanks a ton.
    Ghetto Rig
    Power: HK AVR245.
    Speaks: Rti4.
  • johnADA
    johnADA Posts: 98
    edited May 2006
    Glad someone else said it.
    Same goes for power conditioning, speaker wires and video cables.
    One larger piece within the center of what philes post as sub standard makes all the difference in the world, OK!!
  • michael_w
    michael_w Posts: 2,813
    edited May 2006
    That's odd but glad you got things fixed. You probably just had a short somewhere...
  • noimposse
    edited May 2006
    I think it may have been a strand from the +/- being frayed at the speaker end so when there was enough power it would short out.
    One more reason I need to get some real speaker wire.
    Ghetto Rig
    Power: HK AVR245.
    Speaks: Rti4.
