RT3000 sub not going, need schematic
brody05
brody05 Posts: 329
edited May 2006 in Troubleshooting
Hi all,
Can anyone help with a schematic of the RT3000 sub, on the circuit board the chip number 45800 (or 4558DD or 45580D - hard to tell if they are 0's or D's) is cracked and charring around it, have it at the repair shop in New Zealand but the dude needs a shcematic to try and figure it out and as to what has caused it. He mentioned C/R U5 which may narrow it down.
Thankyou for any help you can be
Brody
Post edited by brody05 on
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    I would try customer service, shoot them a request and they should be able to answer your question.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited May 2006
    Hello,
    Helen, in our customer service department, has provided the necessary amplifier information via email. Let me know if there is anything else we can provide.
    Regards, Ken
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    See.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • brody05
    brody05 Posts: 329
    edited May 2006
    Thank you very much. It has been a while since I visited the forum, but happy to be back. Will post what caused the problem once repaired incase someone has the same problem.
    Cheers
    Brody
