Can SDA-1 be used with SDA-1C in a HT sucessfully?
francis1967
francis1967 Posts: 161
edited April 2006 in Vintage Speakers
Trying to put together center channel speaks for my HT after having found a pair of SDA-1Cs as mains, I have come across a pair of SDA-1 speakers. Thinking that I might be able to use one as front center and the other as rear center (my wife just left me so I don't give a s**t about having 4,5, 6 or however many monoliths it will take in my living room to make me forget her and immerse myself in hollywood reality!), would this work?
If not for center channel, how about using the SDA-1 speaks for full-range rear surrounds? This is getting better and more wild as I keep writing. Maybe I should just get SDAs allround for a 7.1 setup, throw out one recliner put myself in a sweetspot that can't be beat.
Seriously though, can I any sda's in my application?
Post edited by francis1967 on
  • read-alot
    read-alot Posts: 812
    edited April 2006
    I don't have a problem.
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited April 2006
    What is the purpose of the CRS above each SRS?
  • read-alot
    edited April 2006
    Raife, They are just up there until I get the theater set up down stairs.
    Are the parts to update the crossovers in the SRS still good or have better options come up since your guide from a couple years ago?
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • francis1967
    edited April 2006
    Read-Alot: Is that a CS400 you have as center speaker?
  • read-alot
    edited April 2006
    400i
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • francis1967
    edited April 2006
    Thanks...that's what I will be looking for then...
  • ESavinon
    ESavinon Posts: 3,067
    edited April 2006
    You really need to get rid of those sda crs;) .
    They're horrible for surround sound :p .
    I can help by taking them off your hands:D .
    That's the least i can do for you;) .
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
