RT2000i Midrange rattle.
tuumi
tuumi Posts: 2
edited April 2006 in Troubleshooting
I've been happy with these for a few years now. I have dreamed of owning a decent pair of Polks since I was a kid and saw those speakers from the early 90's that had all those woofers. Anyway, I saved for a few years to buy that one pair of speakers I could have for a long time. So...this is bumming me out. The mid range woofer, whatever you call it. The medium speaker rattle and sounds distorted at medium levels. I pcan lightly press the outside edge of the driver and it disappears. Can it be replaced?
Post edited by tuumi on
  • Skynut
    Skynut Posts: 2,967
    edited April 2006
    The driver can be replaced.
    It is pretty simple if you have allen wrenches and a screwdriver.
    Contact polk customer service for a replacement.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • miner
    miner Posts: 1,305
    edited April 2006
    Most likely a voice coil problem. Talk the Ken in cutomer service.
