replacing push in terminals on monitor 4.6
catzcradle
catzcradle Posts: 13
edited March 2006 in Troubleshooting
I've got a pair of monitor 4.6's and wanted to replace the back plate with a 5-way binding post version. I have the new back-plate, but when I pull the original out, the crossover and backplate are one assembly. Is there some way to seperate the terminal plate and mount the new one, or should I just leave it alone?
HT System:
Outlaw Audio model 1070 Receiver
Sony DVP-70 DVD
Dish 611 HD DVR
Polk SRS 3.1 mains
Polk Monitor 4.6 series 2 Side surrounds
Polk Monitor 5Jr Rear surrounds
Polk CS-350 Center
SVS PCi 20-89 Sub
Post edited by catzcradle on
    F1nut Posts: 50,841
    edited March 2006
    Can you post a pic?
  • dorokusai
    dorokusai Posts: 25,577
    edited March 2006
    There may be a screw or hex bolt that holds the crossover to the old "backplate". As mentioned previously, a picture would help.
    Do they look like this?
  • catzcradle
    edited March 2006
    Yep, thats them.
    Well, I got adventurous, and found that they were basically hot-melted and soldered onto the terminal plates. So, I was able to unsolder them and replace them that way, and they seem to be fine. Didn't think of posting a picture for some reason.
    HT System:
    Sony DVP-70 DVD
    Dish 611 HD DVR
    Polk SRS 3.1 mains
    Polk CS-350 Center
    SVS PCi 20-89 Sub
