AudioQuest speaker cables for LSi25s?
aat
aat Posts: 45
Hi experts,
Do you guys know which AudioQuest speaker cables to use for the LSi25s?
Thanks in advance,
AAT
Post edited by aat on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2006
    Anything will work if they are speaker wires?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • mantis
    mantis Posts: 17,629
    edited March 2006
    Look into the Rockefellars. They have bi wiring ability as you can order them that way or use them directly in 2 conductor mode.They are around 600.00 or so depending on the length
    This depends on how you are going to use the subs.If you are using the subs in the speakers via LFE then using 2 conductor is the way to go.
    The CV8's will work as well but only in a 2 conductor setup. I use these cables.They are also around 600.00 for the pair depending on length. Longer they are more money. For 8 feet they are 595.00
    Dan
    Dan
