Rotel vs ???
janmike
I am looking to either selling my Rotel 1080 and adding a five channel amp or keeping the Rotel and adding a 3CH amp. If I add a 3CH, I would look at the RB-993 and keep the power consistent for all 5 channels. Adding a 3CH or purchasing a 5CH and staying with Rotel, works out to be about the same $$. Either way it is 200WPC. The question is, has anyone compared the Rotel line to other multi-channel amps for HT. This will only be used for HT and not 2CH music. Just considering my options at this point in time. Thanks folks.
Michael
NORTH of 60°
NORTH of 60°
Post edited by janmike on
Sell the rb1080 and get a RMB1095.
Done deal
DanDan
I agree with Dan.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Since your use will only be HT 1095 should be an easy solution. However, if music is ever in the future, 1080 is opined to be better for music. For me, I would get the 993. That way, you can have various options of reconfiguration open to you....System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD -
So do you believe there are no other amps that compare to the 1095? Staying in the 1095 price range that is.Michael
NORTH of 60° -
Music is in the future (or should I say better music than today), but 2CH will be driven with something like NAIM and not Rotel.Michael
NORTH of 60° -
What is NAIM?Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Michael
NORTH of 60° -
I ownn the RMB1095 and it is very musical. I t has plenty of headroom, power, current and I have 86db 4ohm load speakers. It smiles at them and plays really well. No strain or heat issues.
Just get it and don't look back. For 2k I don't see any amp being better. You have to spend more to get more.
DanDan
Thanks Dan. That has been the route I have been looking. I will probably look for a used one down the road.Michael
NORTH of 60°
