New Polk Virgin
Hi, I was hoping you guys could give me some advice about what I have set up for a system. I'm terribly uneducated with home audio stuff. I have a HK AVR235 Receiver and just picked up RTi10 front speakers and RTi6 for rears and I have a Bose VCS-10 center channel and Athena 10" AS-P400 sub. I have all the Polk speakers bi-wired with 12 gauge Monster wire. Is the avr235 good enough to power the set up I have? Any suggestions? Thanks.
Post edited by cutlass on
cutlass wrote:Hi, I was hoping you guys could give me some advice about what I have set up for a system. I'm terribly uneducated with home audio stuff. I have a HK AVR235 Receiver and just picked up RTi10 front speakers and RTi6 for rears and I have a Bose VCS-10 center channel and Athena 10" AS-P400 sub. I have all the Polk speakers bi-wired with 12 gauge Monster wire. Is the avr235 good enough to power the set up I have? Any suggestions? Thanks.
I'm learning as well, but I can try and help. I would say the avr235 will power your set-up, but you'd be getting a lot more with a separate amp to power the front speakers and center channel. I've seem 3-channel amps around for such setups. I'd also look into getting a CSi3 or CSi5 center channel. Your front stage will blend better when your speaks are matched.2 Channel
Vandersteen 3a Sigs
Music Reference RM-200
Hovland HP-100
VPI Scout w/ Benz Ace
Rotel RCD-1072
Cardas Golden Reference Speaker Cables
Cardas Golden Reference Interconnects
Cardas Golden Power Cords
PS Audio UPC-200HB
Black Diamond Racing Isolation -
cbl117 wrote:I'm learning as well, but I can try and help. I would say the avr235 will power your set-up, but you'd be getting a lot more with a separate amp to power the front speakers and center channel. I've seem 3-channel amps around for such setups. I'd also look into getting a CSi3 or CSi5 center channel. Your front stage will blend better when your speaks are matched.
good advice..
cutlass, it all depends on what level you want to take your home theater system to.. yes the HK will work fine. as cbl said.. you would be best to match your center channel with your main fronts. will blend and sound better.
Followed by a more powerful sub.. but that can wait if needed.
A seperate amp is always a great idea.. it's all for the better... rarely will an external amp lower the sound quality.. there again... if you are looking to put together a decent home theater system... you're on your way man.. just how far do you want to take it? How deep are your pockets?
PolkFest 2012, who's going>?
Hi Cutlass and welcome to the forum. Your HK is nice and will d a good job. As danger boy said an external amp for the front speakers will add to your sound quality. Plan your upgrades according to your budget and needs. Remember that your source (CDP or DVD) is the most important piece in your system. Welcome and good luck with this hobby:)Carl
All HK receivers has great quality. You'll never will be dissapointed with brands like HK, Marantz, Denon Yamaha, POLK !!!!!!
I can't say the same with brands like Pioneer, Sony, etc .....
My current new system (step by step
A/V Receiver: YAMAHA RX-V657
DVD Player: YAMAHA DVD-S657
Main Towers: polkaudio® Monitor 50
Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² ) -
All in all your system is pretty good! However the biggest weakness in your system would be the Bose center channel. Please don't take this personal, but that is by far the worst center channel I have ever heard at any price. I would heavily recommend a Polk CSi5, or if you don't have the space for that you could also get good results with the CSi3. I can not even begin to describe how much better the CSi center will sound over the Bose. In fact if it were my system I would be tempted to turn the center off in the receivers settings and let the RTi10s take care of the dialog in the meantime.
Also as mentioned before your RTi10s could benefit from more power, but that is always something that can be done later if you choose.
Hope this gets you headed in the right direction. And remember CHANGE THAT CENTER!:D
Welcome to the Club!!!!!
DaveHT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
This could be the funniest thing I've read on this forum so far:
"Please don't take this personal, but that is by far the worst center channel I have ever heard at any price."
Thanks for brightening my day, Dave.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Wow. Glad I could help.:)HT
2 CH
Thanks for all the input. If future shop has a csi5 in stock, I'm going to pick one up today. You're right the Bose doesn't cut it. As far as another amp goes any brand suggestions?
Parasound & RotelHT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
I would do some searching around the forums for recommendations. There are many good options.
Just a few off the top of my head.
Adcom
Outlaw Audio
Rotel
Parasound
B&K
Sunfire
NAD
Eathquake
QSC (pro audio stuff)
Krell
Keep in mind there are many good deals to be had on the used market.
DaveHT
2 CH
You should deffinately have the same timbre match for your RTi10's. You should get the CSi5.Yamaha RXV-757
JM-Lab Focal Cobalt 816 S's, JM-LabFocal Cobalt CC 800 S, FXi3's, RT15's & PSW 303 -
You can thank Audiobliss. Here's a link to my message thread where he posted links to all these manufacturers. I think it's the third message down.
http://www.polkaudio.com/forums/showthread.php?t=38982Home Theater In Progress
Samsung 4272
Denon 3910 Universal Player
Anthem AVM-20
Anthem Statement A5
Fronts LSI-25
Center LSI-C
Surround LSI-FX
Getting closer to complete!:D -
Thanks guys! After an hour in the pathetic Future Shop in our city, I went over to another store that carries the CS series of Polk. Ended up buying a CS1 center channel. I know it's not as big and powerfull as a CSi5, but Holy crap, it's like night and day compared to that Bose. I can't believe I used that thing for the last 2 years. So now I'll spend a bunch of time researching amps based on the info you guys have given me.
Thanks again, it's great to see an online forum where people actually reply to questions and are so helpful. -
honestly, you wasted your money. At least you should've went with the CSi3 but even then the 10's will overpower it. You should've either kept the bose til you can afford the 5 or go ahead and spring for it now. I know it was a big upgrade but all you did was delay the inevitable.
welcome to the forum.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Sorry Cutlass....but Toxis is right. If you can I would return the CS1 and get a CSi3 or 5. It truly is worth the extra. I know that CS1 is a HUGE improvement over the bose, but it still is not properly timbre matched to the RTi10s. Just try to imagine sound even better than what you have now that perfectly blends with your 10's. All I can say is it's, worth it, worth it, worth it!
Just tryin' to get you and your system up to it's potential.;)
DaveHT
2 CH
Hey guys, point taken. Just got back from returning the CS1. Got a shiney new CSi5 sitting on my tv. Definately an improvement over the CS1. I had pretty much came to the same conclusion today before I read any of these comments after listening to it for a couple of hours.
Dave. -
GOOD MOVE!!! Now give it a few days to break in and you'll really start enjoying it.Never kick a fresh **** on a hot day.
SWEET!! You made the right choice. Congratulations.
It should give you years of enjoyment. That is if you can keep the upgrade bug away that long.:DHT
2 CH
Hi Cmy !!!cmy330go wrote:Sorry Cutlass....but Toxis is right. If you can I would return the CS1 and get a CSi3 or 5. It truly is worth the extra. I know that CS1 is a HUGE improvement over the bose, but it still is not properly timbre matched to the RTi10s. Just try to imagine sound even better than what you have now that perfectly blends with your 10's. All I can say is it's, worth it, worth it, worth it!
Dave
A question....The CS1 is a perfect match, for example, with Monitor 50 floorstanding...or maybe i should look CS2 ????My current new system (step by step
*Seby*-Polk- wrote:Hi Cmy !!!
Either of those centers are timbre matched to the Monitors. I have found in the past, mainly with the RTi series, that sometimes a small center can be somewhat overpowered by large towers at medium to high volume. Your monitor 50s in my opinion are probably right on the edge. I have not had extended time to listen to the Monitors so I can't really give you a strong opinion. By what i can see on paper I would be tempted to say that the CS1 might be a slightly better match for the 50s because all the drivers match. I would think the CS2 would be a better match for the Monitor70 since they both have 6-1/2" drivers.
Hope that makes sense. Haven't had the morning coffee yet.:)
EDIT: As always, if possible. Try both and see what sounds better to you.
DaveHT
2 CH
All good advice, but if this was a boating forum everyone would recommend a yacht.
SuperDave
Yamaha RX-V992 (Center,Rears)
Adcom GFA-5500 (Mains)
Denon DVD-1920
Mitsubishi 40" LCD
DirecTV DVR Whole House
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables -
SuperDave wrote:All good advice, but if this was a boating forum everyone would recommend a yacht.
A simple Runabout will do. We can even keep it music related.:D
http://www.therunabout.com/
I think you'll find it has a very modest base price.;)HT
2 CH
Ha ha ... ok Dave....The CS1 sounds better with monitor 50's....that's right..(5"1/4) same timbre.cmy330go wrote:Either of those centers are timbre matched to the Monitors. I have found in the past, mainly with the RTi series, that sometimes a small center can be somewhat overpowered by large towers at medium to high volume. Your monitor 50s in my opinion are probably right on the edge. I have not had extended time to listen to the Monitors so I can't really give you a strong opinion. By what i can see on paper I would be tempted to say that the CS1 might be a slightly better match for the 50s because all the drivers match. I would think the CS2 would be a better match for the Monitor70 since they both have 6-1/2" drivers.
DaveMy current new system (step by step
would it be honest for all of us to say "Sell your LSi's, Get R30's all around!!" or would it be to tell people to get what will sound best for their setup? If this was a car forum and I had 3 20" rims and wanted a 16" just to get me by, do you think anyone would actually tell me that would be ok?SuperDave wrote:All good advice, but if this was a boating forum everyone would recommend a yacht.
