Blown mid-range?
rt1000jimbo
rt1000jimbo Posts: 3
edited March 2006 in Troubleshooting
How do I remove the mid range from my RT1000i to check if it is blown? :confused:
Post edited by rt1000jimbo on
    VR3 Posts: 28,821
    edited March 2006
    That thing has the baffle right?
    Take out the allen screws - the woofer is just setting in there... (pressure fitted with the baffle)...
  • Eric W
    Eric W Posts: 556
    edited March 2006
    Yup, they are 9/64". Lie the speaker on its back to take out the mid range driver.
    -Eric
    -Polk Audio
  • rt1000jimbo
    edited March 2006
    Got it! The thing was press fit so tightly I wasn't sure if it was fastened from the inside. All indications are that the speaker is blown. Is there anyway to repair the thing? or would it be best replace it?.Thanks guys.
    Jimbo
  • simmtron
    simmtron Posts: 1
    edited March 2006
    Your out of luck, they don't make the speakers for this speaker anymore. I needed a replacement for my rt2000i they said to use speaker from rti8 series, which means replacing both speakers (better imaging). I found someone selling one speaker on ebay with woofer I needed. A lot cheaper too.
  • rt1000jimbo
    edited March 2006
    MW7200 speakers were still available. Replaced blown with same available from polk.
