lawnmowers??
PhantomOG
so i just mowed my lawn for the first time (ah, the joys of homeownership) with a POS mower that was kindly given to me. it was just a cheapo side shooter that almost killed me with the flying grass and my horrible allergies, as well as make the sidewalks and driveways look like crap from all the loose grass.
ANYWAYS, I want to buy a decent mower with a bag catcher but I don't know squat about what's good or bad in brands etc. How many HP do I need for a relatively small yard with bermuda grass? What brands are good? Are they all the same?
Thanks for helping. I appreciate any and all advice. Even telling me to pay someone else to do!
EDIT: also need a good weedeater for the tight spaces so any suggestions there are also appreciated.
Of course Honda makes a good mower but I like my Toro. I use a 5hp for a thick grass large yard. It does the job but I wish I had a 6.5. Mowers for me have been pretty much fool proof, as long as you take care of it like any other item(oil change, good blade), it should last a long time. As far as weed eaters all I can suggest is by gas poweredMatthew
Sometimes the road less traveled is less traveled for a reason
HT
Yamaha RX-V2500
CS400-Center
SDA 1A-Mains
RT20-Surround
None right now-Rears
SVS 20-39PCi
Infocus IN72 -
FWIW, I've got a Honda pushmower (self-propelled, rear bagger) that I bought in 1978. Still runs good.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
I hate buying them, what a waste of money. So with that I buy a model or two above teh cheap ones, to me they are all the same. The one I have is a Sears, waited for a return and took the discount.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
We use a mower from the 60's...
It had its first oil change in 10 years last year..
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I'm with hoosier. I buy a decent (but not TOTL) mower. I look for decent wheels that adjust easy and a Honda motor. Briggs and Stratton sucks balls.
If you mow your lawn more often you wouldn't have as much mess...
Bag mowers are a pain in the ****. You're better off going with a mulching mower that "re-cuts" the grass into tiny parts that you can't see / don't make a mess.If you will it, dude, it is no dream. -
craftsman is pretty good too, i got the riding mower (dude, its the only way to fly!!)Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
+1 for Toro
I have a 10 year old 6.5 horse mulcher/bagger and love it. Still starts on the first or second pull, and burns no oil. Seems bullet proof.HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
Toro. The one I have now is 18 years old and still going strong. The one before that lasted about 18 years. I've been mowing yards since I was 9 (43 years) and only used 3 mowers....All Toros. It is almost impossible to tear them up."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
I wish I could get away with a push mower:)
Stay away from Briggs and Stratton engines. Go with a Honda or Tecumseh. For a 22" cut, at least 6.5 HP. The more HP, the less it has to work. I would avoid belt driven self propelled, also.
When you do buy a new one, buy an extra blade and learn how to keep it sharp. Makes for a nicer cut, and less work for the engine.
Keep the grass height to at least 2 1/2" to 3" and use a mulching mower. It self feeds the lawn, and you don't have to get rid if clippings.
For weed eaters I use Echo. I have one that is interchangeable, that is you can use different tools with the same power head. Might be worth looking into, as it is multi-purposed. -
My last lawnmower was from Montgomery Ward.....used it for 23 years. One oil change and changed the blade once.
Currently using bottom of the line Craftsman....not bad, but I should've spend a little more for a Honda. Nothing wrong with the Craftsman, just that some of the designs need better implementation. -
Sears has the 2005 models on clearance sale on their website. I have the Bob Vila model front drive with tall rear wheels, 6.75 hp, convertable side discharge for around $300 last summer. I've had Honda, Husky, and Snapper and the Craftsmen holds it own with them all.
For a trimmer, I got the Craftsmen $200 4 stroke model. Better than the Ryobi 4 stroke it replaced. I won't mix oil and gas again, hate the hassle of 2 tanks.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Find a used Lawnboy 2 cycle pushmower with a mulching attachment. Those 2 cycles never die, and can run on steep banks if need be. They don't sell new 2cycle lawnboys, due to emissions restrictions, but they really can't be beat!Ludicrous gibs!
If you had a bad experience with a B&S, it's because you never owned a real lawnmower.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
My Craftsman has a B&S I believe.Living Room 2 Channel -
Thanks everyone. I think I'll look at the Honda and Toro models, maybe consider a mulcher as well.
I know I should mow often, but I just moved in and the grass was already long and it had been raining the past couple weekends. -
If your lawn is small enough, I can recommend the Black & decker electric mower. Takes a time or two to get used to and I wouldn't want to do more than a quarter acre with it, but its sooooo much easier to deal with than gas and it's got zero maintenence.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
I would suggest a large stock of extension cords if you decide to go that route.Ludicrous gibs!
I'm a Honda fan. I think the double blade setup they use is one of the best setups for both mulching and bagging. I picked up one from Home Depot as a "refurb". It looked like new, but it was about $150 cheaper, same warranty. I've been using it without trouble for a few years now. It always starts on the first pull.
nadams wrote:I would suggest a large stock of extension cords if you decide to go that route.
heh... haven't run over one yet. But the wife has nicked 'em a few times.
That reminds me of another advantage: They're light enough & start so easy that the wife will actually mow the lawn.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
If you have a small lawn, it probably really doesn't matter what you get (it won't get all that much use). My first B&S mower gave me quite a few years of good use (I bought it used for $50 bucks, and only replaced it when I moved 10 years later). The Honda's will probably never die on you, but they cost quite a bit ($500). Koller also makes a decent engine. Now I have a 25hp tractor with a 52" cut with a Koller.Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64 -
Ha, random funny story. When I was a kid, and we first moved to NH and had a lawn, my dad went to a local hardware store (it was a chain store, I forget which one... Grossman's maybe) and financed a new mower. It was some deal where you don't pay for the first month, adn then you get a bill. And it was an expensive mower too. Well, he never got a bill. He even called them and made sure they had his address (without outright telling him he didn't get a bill). Never got a bill. A year later the thing broke, and he brought it in, and they serviced it, UNDER WARRANTY, despite the fact that he never paid a dime!
That mower lasted like 6 years.
Admittedly not the most honest thing to do, but.... free mower.If you will it, dude, it is no dream. -
I think you mean Kohler, they're local here, just like Briggs & Stratton. Kohler makes a great product. -
Another TORO owner here. Great mower.
getcha one!!!"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
(sorry, your right it's Kohler. Koller makes faucets!).Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
Csi-40 Center
PSW350 Sub
Denon DVD-2910
I've had lowe's, craftsman, toro and honda. The Honda in my humble opinion cut no better than the other models and was WAY more expensive. Right now I use a self propelled Toro with mulching kit and a 2004 craftsman rider with a mulching kit. In the price range, I don't think you'll get much better than craftsman. If you want to step up to the big boys like Honda or Deere, expect to pay as much for a push-mower than riders in the "cheaper" brands. Maybe you get what you pay for, but I change oil, filters and plugs seasonally and they run just as well and cut just as well as the day that I bought them. Just my humble opinion.Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
I have an entry level John Deere push mower. The model number is JS60 I believe. Bought it 8 years ago and have not had a single problem with it.Proud SOPA Member since 2005!
Knock on wood! This thread has jinx written all over it.Proud SOPA Member since 2005!
