groove tube 6922(6dj8)
marvda1
marvda1 Posts: 4,951
edited February 2006 in 2 Channel Audio
anyone know the oem manufacturer of the groove tube 6922 tube as they only rebadge tubes.
Puritan PSM156
Post edited by marvda1 on
  • marvda1
    just got the answer, i would stay away from groove tube they use different manufacturers one time you might get jj's. then ei's or sovtek's plus they tack on their added price.
    Puritan PSM156
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    They're Russian in origin. Which factory? I don't recall.
  • ND13
    ND13 Posts: 7,601
    I can't complain about the pair I got for under $20 shipped. So far, just as good as any newer production tubes I've tried. YMMV
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Nothing wrong with GT at all.
  • ND13
    ND13 Posts: 7,601
    People seem to forget that tube re-branding has been going on since the beginning, nothing new here. I have vintage Amperex tubes with Mullard labels, Siemens with CBS labels, RCA with Raytheon labels and so on.
  • audiobliss
    audiobliss Posts: 12,518
    So, if they're labeled Mullard, CBS, and Raytheon, how can you tell they're Amperex, Siemens, and RCA?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • ND13
    ND13 Posts: 7,601
    Factory build codes and design
  • marvda1
    my point is why pay premium for gt's if at the time they are jj's when you can just buy jj's at a lower price.
    Puritan PSM156
  • W WALDECKER
    W WALDECKER Posts: 900
    Good point!
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • ND13
    ND13 Posts: 7,601
    I'd say that 2 6DJ8 GTS for less than $20 shipped to my door wasn't paying any sort of premium and I doubt very seriously that the ones I have are JJs anyway. The design of the ones I have look alot like Amperex with halo getters.
  • marvda1
    if they are buying from multiple vendors then you won't know what brand tubes you are getting untill you get them and even then you won't know if you don't know what you are looking at. make sense?
    Puritan PSM156
  • RuSsMaN
    You pay the premium for GT, Ruby etc, because they only select the best of the best, of whatever run at the time. I have NEVER had a GT or Ruby fail, and their matching is premium matching, not your run of the mill single test.
    They do buy from multiple vendors, but they will label each run differently with a specific designation.
    Cheers,
    Russ
  • ND13
    ND13 Posts: 7,601
    You just have to be careful who you buy tubes from online. I got my GTs from Vintage Electronics.
