Need Wall Mount Recommendations For RTi4 Speakers
Greetings All,
I recently purchased a pair of cherry bookshelf RTi4 speakers to complete a 5.1 HT Setup. Both RTi4 speakers will be wall mounted & serve as surrounds. Here the dilemma. I am seeking recommendations for a specific wall mount option that works well with the RTi4 speaker. A particular part# would be greatly appreciated.
This forum & audioholics.com has been a lifesaver throughout the process of purchasing A/V components for a first timer.
Thanks again,
John
My System
Polk RTi8's - Fronts
Polk CSi5 - Center
Polk Rti4's - Surround
HSU VTF-2 MK2 - Subwoofer
Pioneer VSX-52TX - Receiver
Panasonic F86K - DVD Player
Blue Jeans Interconnect Cables
Belden 5000UP Speaker Cable
Thanks again,
John
My System
Polk CSi5 - Center
Post edited by JEidt on
I use the B-Tech BT77 wall mounts.
-Lou -
smart inverting those 4's Lou. Most would never think to do that, evem at that height.
Good eye!
I played around with them both ways and felt it sounded best with all three front tweeters within 6 inches of each other height wise.
-Lou -
Go to crutchfield.com, they have some really good speaker mounts for good prices. I hung 4 Monitor 30s form the ceiling joists and can put them at any angle I want. They weigh 9lbs, don't know about yours but they have some that can hold up to 20lbs, good luck!NOT MUCH, BUT IT'S ALL MINE!
SONY 60" SXRD (HDTV)
Explorer 8300HD (HD-DVR CABLE BOX)
Toshiba SD-3750 (DVD PLAYER)
Onkyo TX-SR702 (RECEIVER)
Polk Monitor 60 (FRONTS)
Polk CS2 (CENTER)
Polk Monitor 30 (SIDE SURROUNDS)
Polk Monitor 30 (REAR SURROUNDS)
Mirage Omni S-12 (SUBWOOFER)
Tripplite HT 1000UPS (POWER PROTECTION)
Omnimount (CENTER CHANNEL SHELF)
B-Tech BT34 (SURROUND SPEAKER MOUNTS) -
I second the BT77's. I've got mine holding RT35's. Very sturdy wall mounts.
Why do you need wall mounts?? the Rti4's hang on there own. Keyhole
DanDan
Wall mounts allow for angling the speaker to the listening area. Keyhole mounts would limit the position of the speaker and may not give the best sound experience.
I prefer the shelf-type speaker mounts for speakers of this size. Any othe arm mounts make me concerned that the joint may weaken over time.
-Lou -
louhamilton wrote:Wall mounts allow for angling the speaker to the listening area. Keyhole mounts would limit the position of the speaker and may not give the best sound experience.
-Lou
Any links to this type of mount? I'm considering RTi6's & wil need a way to mount them to the wall or put them on stands. They'll be used for the rear surrounds. -
Here you go...
Crutchfield:
http://www.crutchfield.com/S-UZUAZYT...earch=b%2Dtech
B-Tech Website:
http://www.b-tech-int.com/
-Lou -
Thanks!
