how loud do you go?
krabby5
krabby5 Posts: 923
edited February 2006 in Electronics
How loud do you all listen to your dvd movies?
I'm talking to those with receivers where it goes from -80db to +??
I pumped the Pioneer Elite up to -26db last night on "Empire Strikes Back"
With all my upgrades, it was like seeing the movie for the first time again :D
Although when watching cable, I usually am in the -30 to -40 dbs
Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
Post edited by krabby5 on
    heiney9 Posts: 25,497
    How loud do I go? I can yell pretty loud, you could hear me way across the yard.
  • Willow
    Willow Posts: 11,257
    :eek: ;)
  • Ricardo
    Ricardo Posts: 10,634
    I have a Denon 3803 which I calibrated to 75 db at "0"; I normally listen to DVD movies between -15 and -10 (loud); Sometimes I might go between -10 and -5 if sound effects call for it :)
    For TV, there is so much difference between different channels that it is anything between -25 and -10
    SOPA
  • cfrizz
    cfrizz Posts: 13,415
    I generally listen to movies @ -20 to -30.
  • Willow
    depending on the source, -25 to -50
  • unc2701
    unc2701 Posts: 3,587
    I go to 11.
    Backburner:Krell KAV-300i
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    Music at high levels (saturday afternoon) -15 to -5 db. :D Normal: -30 to -20db
    Movies at night -45 o -30 db .. Enjoy the power !!!!
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
  • krabby5
    krabby5 Posts: 923
    holy crap....that's fricken loud!
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Krab,
    The type or scale design of the gain measurement is irrelevent. If not already done consider calibrating the system to THX reference level then talk db down from or above reference level to have a meaningful number to compare to others.
    RT1
  • danger boy
    danger boy Posts: 15,722
    lots of things come into play though for volume settings.. we all have different speakers, different amps/receivers/rooms acoustics, seating positions, hearing abilities... so what may be loud to you is quite normal volume to another listener.
    It's easier and more accurate if you use a sound level meter and measure your volume that way. that is a measurement we can all relate to. IMHO
    PolkFest 2012, who's going>?
  • Ron-P
    Ron-P Posts: 8,520
    Calibrated at 75 db I usually watch movies between -18 and -15.
    If...
    Ron loves a film = don't even rent.
  • McLoki
    McLoki Posts: 5,231
    My system is calibrated to reference level (when at 0) and family movies are usually -25 to -30, My wife and I watch at -15 to -25.
    I usually demo my system at -5 to -10 (depending on the movie playing).
    Michael
    I don't have an HT system. My dedicated pre-amp has a stepped attenuator (vol pot.). It has 30 "steps", loudest I will go is 6 perhaps 7 steps and that's loud. Normal running is between 3 & 4 "steps". It is a pretty high gain pre, so much movement is not needed on the vol. to get it loud. Plus my 11's are fairly effecient and I sit pretty close, about 7 feet.
  • seo
    seo Posts: 305
    Nigel: ...the numbers all go to eleven. Look...right across the
    board.
    Marty: Ahh...oh, I see....
    Nigel: Eleven...eleven...eleven....
    Marty: ..and most of these amps go up to ten....
    Nigel: Exactly.
    Marty: Does that mean it's...louder? Is it any louder?
    Nigel: Well, it's one louder, isn't it? It's not ten. You see,
    most...most blokes, you know, will be playing at ten.
    You're on ten here...all the way up...all the way up....
    Marty: Yeah....
    Nigel: ...all the way up. You're on ten on your guitar...where
    can you go from there? Where?
    Marty: I don't know....
    Nigel: Nowhere. Exactly. What we do is if we need that extra..
    push over the cliff...you know what we do?
    Marty: Put it up to eleven.
    Nigel: Eleven. Exactly. One louder.
    Marty: Why don't you just make ten louder and make ten be the
    top... number... and make that a little louder?
    Nigel: These go to eleven.
    From Spinal Tap
    Signature goes here
  • adam2434
    adam2434 Posts: 995
    Levels also vary from DVD to DVD quite a bit.
    I usually run -15 to -20 for DVDs.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • Ricardo
    For me, -10 is about perfect; I like to enjoy the sound effects as if I was in a good theater. Most movies will have an average of (guess) 65-70 db heard at the listening position, with peaks going up to 95-100db or so. I know that at the -10, the first battle of Master and Commander has a peak of 105db at the listening position. That is LOUD, but that's exactly how it should be, and it only lasts a second.....
    SOPA
  • krabby5
    krabby5 Posts: 923
    Krab,
    RT1
    What is THX reference level?
    I had my volume at -30db and used a spl meter to set all speakers at 75db (a little higher for sub) when I had my Kenwood receiver
    when I got my new Elite receiver I just used the auto setup and made sure all speakers were set to "small"...I liked the setting, so I kept it..
  • seo
    seo Posts: 305
    Exactly. Also need to know if it is A weighted, C weighted, etc.
    Signature goes here
  • Drumingman
    Drumingman Posts: 348
    I probally listen at 80 to 95 db.
    Which is anywhere from 15 to 5 depending on the source
  • adam2434
    adam2434 Posts: 995
    I always thought that the Pioneers calibrated a 75 dB reference level to be "0" on the master volume.
    Since you have a spl meter, you can check this.
    Run the receiver's test tone manually and increase the master volume until you hit 75 dB on the meter. See if this is "0" on the volume.
  • wingnut4772
    wingnut4772 Posts: 7,519
    I usually like to go about -10 below reference dependng on the source.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Ricardo
    Good girl......If you ever come around Cincinnati you're invited to watch a movie in the way it is intended to be heard :)
    SOPA
  • RuSsMaN
    RuSsMaN Posts: 17,985
    -182, with 0 being 'Tour2ma' reference level.
  • McLoki
    McLoki Posts: 5,231
    Reference level is 85 db dialog with 105db peaks from each channel. Your sub (due to all other speakers set to small and just cuz it can) gets average levels of 95db and peaks of 115db.
    The test tones on Video essentials are calibrated to be 30db under reference (that is why you set them to 75db) The test tones on Avaya are 20db under reference (that is why you calibrate them to 85db.)
    Movies themselves can run over or under reference. Usually they are close (+ or - 3 to 5 db) but it can make a big difference. That is why if you have not heard a movie before and listen close to reference level, you may want to turn it down a bit for your first viewing.
    Michael
  • Pablo
    Pablo Posts: 723
    I would assume everyone here listens to it pretty loud (that's why we spend that much on equipment). But it depends on the movie. Anything with "things that blow up" goes pretty loud (as loud as it takes for someone to come down stairs and say it's to loud. Then it goes down by 1). for other movies, just loud enough that I don't feel there voices vibrating my body (who needs to feel Rainman saying "it's very sparkelly").
    Denon AVR-3803
    RTi-70 Fronts
    FXi-30 Surrounds
    RTi-38 Back Surrounds
    Csi-40 Center
    PSW350 Sub
    Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
    Denon DVD-2910
    Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
  • adam2434
    adam2434 Posts: 995
    Yeah, I like -10 too, when I'm by myself and want to shake things up a bit. The wife and kids won't tolerate that level though.
  • cfrizz
    :eek: Dang Darla, you must be deaf as a stone or well on your way there!!! :eek:
  • ward91
    ward91 Posts: 338
    when nobodys in i safely leave the volume at "0dB" as that is 80wpc with low distortion(0.08% 20hz-20khz), when i realy pushed it i maneged to get 112db at my old listening position about 2.5m avay from my mains. wit movies i usualy am forced to listen at about
    -24db by my parents but when they are not in i crank it up to about 0db and sometimes +3db on the good bits and usualy about -3dB elswhere
    with music u can crank it up to +3dB and leave it at this for about 2hours (thats how long i have when i get home from school to when my mum gets in)
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • ward91
    ward91 Posts: 338
    you mean -5 to -15 not pluss ??
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • GATOR3000
    GATOR3000 Posts: 355
    Depends on the DVD source DD or DTS. I play most of my movies at 85 to 90 db. Which is in -12 to -6 db range on my receiver.
    Theatre System 5.1
    Sumsung HP-S5053 plasma
    Receiver Denon AVR 3806 Pre/Pro
    Parasound HCA 1500A amp (front L/R)
    Parasound HCA 1000A amp (centre)
    B & K AV5000 amp (bi-amp + surround)
    Dynaco ST70 tube amp (Herbie HAL-O9)
    polkaudio Lsi15 (Cherry) 2-channel
    polkaudio Rti8 Front (Cherry)
    polkaudio Csi5 Centre
    polkaudio Rti6 Surround
    polkaudio PSW1000 Subwoofer (Cherry)
    Original A8T CD
    Pioneer DV-275 DVD Player
    MONSTER CABLE MP-HTS3500MKII Powercentre
