subwoofer low freq
tony27
I just purchased the PSW450 sub. The specs say it can go as low as 25hz. If I have a dvd in and a audio passage hits 25hz going into the sub, can I hear that or is the freq going to be higher than what is being input to the sub?
Tony
Tony
Post edited by RyanC_Masimo on
You should be able to hear/feel 25Hz. Your PSW450 is capable of hitting 25Hz. at -3dB. This means that for a given volume, it will reproduce 25Hz. at 3dB lower volume. Depending on your room acoustics, you may or may not actually be able to hear the 25Hz; this plays a very big role in how your sub will sound. Also make sure you play around with the positioning of the sub.
Aaron -
The PSW450,
can go even lower then 25hz,it can reproduce 22hz at -7bd as I tested it with a tone generator.Its clean and steady.This sub is clean up in the 70hz range as well,not many peeks or dips that I noticed.=or-2 to 5db all threw the range of 150 to 24hz.After that it starts really falling off.
It's an easy sub to setup.Dan
