Psw-350 Help!!!
midnight0045
midnight0045 Posts: 1
edited February 2006 in Troubleshooting
hey, i have had a PSW 350 for about 4 and half years now and a few months ago it became extremely distorted and buzzed at low volumes.. so i figured the subwoofer speaker was blown out so i sent it in and recieved a new subwoofer speaker today and installed it back into the cabinet and the problem consisted but only not as severe... the old subwoofer speaker was exteremely bad but with the new speaker installed the buzzing at low volumes is still present but when turned up it hits fairly hard ... granite it is not hitting to where it should be hitting... all in all.. i tried to fix it.. it didn't work.. what do i need to replace now to make this subwoofer return to how it supposed to sound? the amplifier? is it somehting i can do? or must it be completly replaced?
    VR3 Posts: 28,821
    Well, since you just replaced the woofer...
    I am just going to have to assume its an amp issue... Id give Ken a call at the CS department.
