Speakers Cutoff
guy24682
guy24682 Posts: 11
edited February 2006 in Troubleshooting
I was wondering if anyone knew if the polk audio r30's had a automatic cutoff circuit. :confused:
Post edited by guy24682 on
    F1nut Posts: 50,841
    Is the problem with the tweeters, one entire speaker or both entire speakers?
  • guy24682
    guy24682 Posts: 11
    F1nut Posts: 50,841
    If your tweeters "turn off" and then come back on again after they've had a rest, then your speakers have a tweeter protection circuit. The most likely cause of the tweeters shutting down is that you're clipping (over driving) your receiver, AVR or power amp. The solution, turn it down or buy a better power source.
