Ok, need 1 last part....a sub!
Brewman
Brewman Posts: 12
edited February 2006 in Speakers
Finally getting the ball rolling on my HT setup. Picked up my receiver yesterday (Onkyo 603) and getting ready to order my speakers in the next week or so. Getting RTi4s for the front, CSi3 for the center, and some R15s for the surround (plan on upgrading them later down the road). Now for the key, a good sub to go with all of this. My budget is set at $300 for a 12" sub. I have been looking at the 12" Dayton sub, but after reading some recent reviews of them on other forums, there may be some QC and other issues with the latest offering. My attention then turned to the Velodyne VRP-1200, but it is a little out of the price range right now.
Some background on my room. 19'x13'x8' with the seating on the back 13' wall, entertainment unit up front. This system will be used 90% movies/gaming, 10% music (if that). I do listen to concert DVDs if that sways my music estimation.
Any opinions on those 2 subs, or any others would be very helpful (so would some links to sales ;) )
Thanks!
Post edited by Brewman on
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    PSW 12 ??? You try it ??? Anywere Velodyne works great. Go it :)
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
  • Early B.
    Early B. Posts: 7,900
    If you only have $300, save up to about $500 so you can get a Hsu STF-2 or entry level SVS. No point wasting time with a weak sub for a room of your size. I have the exact same size room, BTW. The Dayton subs are great, too. Don't rule them out. Parts Express has great customer service if there's ever a problem.
    "God grooves with tubes."
  • Ron Temple
    Ron Temple Posts: 3,212
    I agree on the new Dayton subs, QC is not up to snuff on the first batch. You should be able to find a decent price on the Velo in your budget. Your next best option is the Bic Acoustech H100 or Cadence XSub both ~ $250. Early is right about saving, the Mirage S12 from Vanns is a steal @ $400 shipped, the Hsu or SVS PB10 (my favorite) are in a different world than the budget subs.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • *Seby*-Polk-
    Yamaha Subwoofers are goo? Any body know it ???
  • crossroadazn
    crossroadazn Posts: 69
    For $300 you should look in not used much entries like SVS, HSU, Rell or any sub that is fast to keep up with your small book shelfs. You donot have to get much power say 150w and up. Happy hunting. :D
  • Brewman
    Brewman Posts: 12
    After some more research, I am really leaning towards the Mirage S12 for $400 shipped. I can't find any bad info on it, and that is my cap, $400. Almost another $100 for an SVS is just too much. I think I'll be more than happy with it.
  • tommyboy
    tommyboy Posts: 1,414
    Thanks!
    As a person who had the vrp 1200, I was very dissappointed with it. I work at circuit city and every vrp (10 and 12) we have had and used at the store has been blown. Now I know at the stores the get used very hard but when I had mine at home I was always afraid of that happening. And to tell you the truth, the thing never turned on unless you put in a movie or turn the volume up high then turning it down again (which to me is annoying in the first place). Lastly, the bass to me was... dissapointing. It doesn't "rattle your house" like people say. So I got rid of the VRP and got the DPS 10" instead, and WHAT A DIFFERENCE! At circuit city, we have had two Dps 10" on display since it came out and it sounds just as good as the day it came out of the box. The bass hits so much harder and cleaner then the VRP 12" ever could. VRP is velodyne's cheapest model and the make it that way. I might have gotton the DPS a lot cheaper but It is DEFINITELY worth the extra $100 for the dps 10 " . believe me. So If I were you(and if you decide to get the vrp thats fine with me, just giving my opinion), I would save up a little more cash so you won't bring a sub home and be dissappointed like I was :(
    hope this helps :)
    tommyboy
    AVR: H/K AVR240
    Fronts: Monitor 50s
    Center: CSI3
    surrounds: R15s
    Sub:Velodyne DPS10
    Dvd/Cd: Samsung HD upconverter (for now)
    TV: 50" Sammy Plasma
    game hardware: 360 and gcn.
    Gamertag: kovster27
  • tommyboy
    and by the way, my room is 20x13 and the bass from the dps completely fills my room. So don't let the 10" scare you off.
    AVR: H/K AVR240
    Fronts: Monitor 50s
    Center: CSI3
    surrounds: R15s
    Sub:Velodyne DPS10
    Gamertag: kovster27
  • Brewman
    Brewman Posts: 12
    Well, looks like I spoke too soon, the Mirage is out of stock again...
    back to looking again. ;)
  • bms
    bms Posts: 182
    I don't have a lot of HT experience, and I've just recently updated my system from old 2 channel w/ Bose 901's to 5.1. I have all the same components as you, including the Onkyo 603, except I have RT5's as front R/L. My room is is also very similar, 21' x 13' x 8', with an openening into another 12' x 12' room.
    After much research I decided on the svs pb10, and it's really great. Deep & loud, it really does the job. I paid $429 + $40something shipping to PA, and I'm more than satisfied. The first time I listened, I was shocked at the depth & volume. Also, the guys at svs were great to deal with, returning calls & emails promptly. I'm an svs guy now.
    BTW the r15's are working just fine as surrounds (esp. for only $99.00/pr.).
    bms
    Family Room:
    Onkyo TX-RZ920
    Outlaw 2200 monoblock amps x 3
    Sony UBP-X700
    Sony A80J 77” OLED
    Polk LSiM 705’s
    Polk LSiM 706
    Polk LSiM 703’s
    Polk RTi4's
    Dual SVS PB13-Ultra’s
    PC13-Ultra
    Bonus Room:
    Onkyo TX-SR806
    PS3
    Panasonic TC-P42G10
    Polk RTi10's
    Polk CSi5
    Polk R50's
    SVS PB10-ISD
    For sale:
    Onkyo TX-SR603X
  • Brewman
    Brewman Posts: 12
    Thanks for that info bms, I really like that SVS, but thought I was getting out of hand with the cost of the sub compared to the rest of the system. If the Mirage doesn't come back in stock soon, maybe I'll just go ahead and get the PB10 and be done with it. ;)
  • tommyboy
    I thought people would think my system is be odd having three different series polk for one system (CSI3 center,Monitor50 fronts, R15s surround) but its feels good that Im not alone :)
    AVR: H/K AVR240
    Fronts: Monitor 50s
    Center: CSI3
    surrounds: R15s
    Sub:Velodyne DPS10
    Gamertag: kovster27
  • tommyboy
    I still as of now wouldn't have bought an SVS (only because I got a new velodyne DPS 10" for $170) but when I decide to upgrade years down the road, that brand will be on the top of my list from what I hear
    AVR: H/K AVR240
    Fronts: Monitor 50s
    Center: CSI3
    surrounds: R15s
    Sub:Velodyne DPS10
    Gamertag: kovster27
  • bms
    bms Posts: 182
    If you watch a lot if bassy movies and listen to prog. or other bass-heavy music like I do, it will do well.
    You won't regret it!
    bms
    Family Room:
    Onkyo TX-RZ920
    Sony UBP-X700
    Sony A80J 77” OLED
    Polk LSiM 705’s
    Polk LSiM 706
    Polk LSiM 703’s
    Polk RTi4's
    PC13-Ultra
    Bonus Room:
    Onkyo TX-SR806
    PS3
    Panasonic TC-P42G10
    Polk RTi10's
    Polk CSi5
    Polk R50's
    SVS PB10-ISD
    For sale:
    Onkyo TX-SR603X
  • halo
    halo Posts: 5,616
    +1 for the SVS. I have the 20-39 PCi and that thing is downright scary :eek: The first time that PB-10 hits (I recommend the Darla scene from finding Nemo) your jaw is going to hit the floor. At SVS they have a 45 day trial period and excellent CS - Talk to Ron S. Good luck! :)
  • steveinaz
    steveinaz Posts: 19,538
    Get the:
    Floorboard ripping, drywall flexing, roof shaking, concrete cracking...
    SVS
    ...and never look back.
  • *Seby*-Polk-
    DAMNNNNNNNNN :( Everybody likes the SVS sub.... why this "machine" doesn't exists hereeeee !!!!!!
  • Ron Temple
    Seby,
    I think they will ship...www.svsound.com. Get a quote.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Brewman
    Brewman Posts: 12
    Well, finally I have some luck, the Mirage S12 came back in stock, just placed my order for one, $400 shipped.
    Frequency Response: 19Hz-120Hz +/- 3dB
    Amplifier Output Power: 300 Watts RMS, 1,200 Watts Dynamic Power
    Woofer: 12" woofer
    Can't wait to get this baby fired up!
  • *Seby*-Polk-
    Thanks Ron...I investigate this site .. ;)
  • Maestro
    Maestro Posts: 92
    I guess the SVS hype didn't close the deal! You guys will have to watch GLENGARRY GLENROSS...
    ...always be closing!
    _________________________
    Main: Polk R50s
    Center: Polk CSi3
    Surround: Polk R30s
    Rear: Polk R15s
    Sub: Polk PSW12
    Cherry Wood Edition
    Whirlwind Cables/Connectors
    Harman/Kardon AVR635
    Harman/Kardon DVD 27
    Sony RDR-GX300 DVDR
    Sony Bravia 40" XBR1
