electrical outlets
marvda1
marvda1 Posts: 4,950
edited February 2006 in Electronics
what is the best quality (sounding) outlet you can get at home depot or lowes? it would help a lot if you know the part number.
thanks
Puritan PSM156
Post edited by marvda1 on
  • dorokusai
    dorokusai Posts: 25,576
    Just look for the words "Hospital Grade", that's good enough.
  • madmax
    madmax Posts: 12,434
    All of us loonies should have hospital grade outlets in our sanctuaries...
    madmax
    Vinyl, the final frontier...
  • RuSsMaN
    RuSsMaN Posts: 17,986
    I use Porter Ports .
    Cheers,
    Russ
  • dorokusai
    Those look interesting and local I see.
  • RuSsMaN
    Yeah, that's Albert Porter. He's the one with the Dali Megalines I was telling you about at Alexis Park. Pro photographer, does a lot of stuff for Audiogon and Stereophile.
    heiney9 Posts: 25,432
    Just wondering Doro/Russ what's the benefit of hospital grade. Durability, build quality, accuracy, less noise, better fit, more reliable ???
  • RuSsMaN
    All of the above.
    The *only* statement I will make now, on power cords, outlets, etc is the following:
    You have a power source in your wall, how you choose to tap that source is up to you.
  • dorokusai
    There's actual standard for it but I'm too lazy to look it up.
    A couple are improved clamping power, longer straps for installation, treated for resitance to chemicals....I'd say that you covered the idea.
  • Holydoc
    Holydoc Posts: 1,048
    Though this is really an advertisement for these recepticles, it does give you good information on the requirements and testing involved with hospital grade.
    http://www.leviton.com/pdfs/hospital/Hospital_Bulletin.pdf
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • dorokusai
    That works, everything technical is sub-referenced within that PDF....nice link Holydoc.
    Thanks guys, and Russ I wasn't baiting you for an :mad: evil :mad: discussion on cables/cords/power conditioners :):p . The rest ah ya's don't be dragging that debate in this thread either....or I'll hafta send Guido out to break your audio equipment :eek:
  • drew spelts
    drew spelts Posts: 310
    you mean the KILLER PIMP???????
    Harman Kardon AVR635
    RTi10's Up Front
    CSi5 Center
    RTi6's Rear Surround
    Furman RA-1210:rolleyes:
