Dual Gas Tank Question...
VR3
How often should I alternate tanks I use...
And would it be wise to have atleast a quarter tank filled in one so if I happen to run out of gas, Ill have a back up plan? lol
I dont want to have gas setting in there a long time (which is why I ask)
Post edited by VR3 on
When I had dual tanks, I would try to switch from one to the other, then back and so on just to keep the gas fresh, good plan to keep a a min 1/4 of a tank at all times.
Just a guess, your mom let you get that truck?Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Yep, its in the driveway!
And thanks...
The reason why I ask about this is - I dont want to fill both tanks....
because it will cost 80 dollars to fill both tanks, and 450 miles to go through both tanks. I do NOT plan to drive alot...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
pics man picsCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Soon, gotta borrow a digital camera...efffffffffffff- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
get some gas in both, run one dry, fill it to whatever, switch to the other, run it dry, fill, switch, run dry, fill, ....
Or do whatever you want it's yoursDodd - Battery Preamp
Ill do that most likely...
Just seeking advice from people whos owned a dual tank before...
From what I was told, if gas is not kept in the tanks for extended periods it will rust...that would suck.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
It`s a good idea to switch back and forth, and run them low enough to keep the gas fresh..but not too low, as the crap on the bottom of the tank will clog injectors, or plug up feul filters
1/4 tank rule is good..I personally never go under 1/2, as it is cheaper to fill up that way, and if there is an emergency you will be prepaired.
If ya stay ready, you don`t have to get ready..
gas will stay good for a month or so, but don`t let it sit too long...if it does throw some premium on it when you fill up to help burn off the crappy gas without fouling plugs..
best thing to do is fill both, run one down, fill it up and switch to the other side andrun it down...rinse and repeat as needed..!
congrats on the new truck
I see a girl friend in your near future..
**snif, snif** our boy is growing up.....Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
N. Carolina regular should be used within 60 days or else you run the risk of gumming things up. Having the tank filled less than full will allow moisture to build up and make things even worse.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Well what I plan to do as of right now...
Is fill one tank up to 1/2 way - run it down... (while the other tank is filled up half way)...
Then when that one tank is empty, I will switch to the other tank... then fill the one I just got through with up to 1/2 way - this way it is even and it will get me a good distance...
Sound like a plan?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Look at this discussion. You guys can overthink ANYTHING, I swear.
Just keep driving, pumping, and flippin' the switch, enough already.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
so you'll fill them to half full, maximum, ever?It's not good, very fundamentally simply not good. - geolemon
im a auto boidy tech and mechanic, the advice i can give is kepp both full if possible if you just keep a 1/4 tank it could condensate and you might get water in your fuel how much who knows, so i would keep them full one at all times and put some fuel stablizer in to keep that fuel fresh.John Tyler Birch
home audio system:
Denon avr-1907
Sony dvd/cd changer 5 disc
nakamichi BX-100 tape deck
2 Polk Audio monitor 70's
Velodyne DPS-12 subwoofer
RCA TV
NAK 600 tape deck
Monster power line conditioning power center -
neomagus00 wrote:so you'll fill them to half full, maximum, ever?
No, if I was planning to go on a trip or w/e (road trip) - I would probally fill them both up...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
also, never run the tanks DRY... it will be a PITA to get the truck started again off of a dry tank. Run it low, but never dry...Ludicrous gibs!
Fill both tanks and run them both. it's expensive at the station, but you don't go as often.
Just my .02. -
Yeah, I just put gas back in the rear tank today (had a gas can in the garage) and it was completely empty (has about an 1/8 of a tank now) and it had a lil extra time to start right but it kicked in finally...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
make sur eit doesn`t leak..
It may have been empty for a reason...
also check and replace old fuel filters and lines...
Just a heads up..
When do we get to see the babe magnet..?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
We are going to replace the oil, etc once it gets insurance and tag on it...
I am kind of under the impression that that tank was just never used....or it was just run all the way down...
The front tank only had... 1/4 tank in it... so its empty to basically...
I plan to take pics in the morning (I got a digi cam for a lil bit) and then Ill post pics...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Check them, they have a thing for leaking. Also go over the brake lines GOOD. They have a thing about rusting and breaking too. Trust me, you don't wanna find out when your doing 65. Personal experience...
Thanks Amul,
I wrote all that down to tell my Grandpaw, he is going to teach me how to change oil and filter and how to lubricate everything....
Dun dun dun- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
^^ Sweet. Should be fun maintaining it.
amulford....you found out your brakes didn't work while doing 65? Sounds, umm, exciting!George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
I agree with beardog -- fill both tanks to start... run one down, refill it, switch to the other... run it down, fill it, switch back.
leaving a tank 1/4 full will result in condensation inside the tank --- in time --- watery gas. baddddd... freeze up a fuel line like that if it get bad enough.
On a side note --- I've got about 1/10th of a tank in the 88.. its basically empty -- by choice -- we were welding so much and grinding and god knows what that i didn't want any more than a gallon of gas in there at a time. I would be well advised to drop the tank come spring.... but i wont... no too safe... lol -- I'm going to drill a hole in the bottom of it, drain it out... flush it with some laquer thinner or gum-out carb cleaner, and then put an oil pan plug in it or something of that nature.... then i'll fill it back up.The Artist formerly known as PoweredByDodge -
Vr3MxStyler2k3 wrote:Thanks Amul,
Dun dun dun
Good deal! Changing your oil is one thing you should never have to pay anybody to do. -
and do it evry 2500-3000 miles without fail..
If it sits, or you only do city driving , do it every other month..
Fresh oil is the key to a long lasting , healthy motor....change filter every time
Air filter also..
and always warm you engine up...EVERYTIME...no exceptions..
okay I`m done preachin...
I very much believe in what I`m sayin though..!!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
PoweredByDodge wrote:On a side note --- I've got about 1/10th of a tank in the 88.. its basically empty -- by choice -- we were welding so much and grinding and god knows what that i didn't want any more than a gallon of gas in there at a time. I would be well advised to drop the tank come spring.... but i wont... no too safe... lol -- I'm going to drill a hole in the bottom of it, drain it out... flush it with some laquer thinner or gum-out carb cleaner, and then put an oil pan plug in it or something of that nature.... then i'll fill it back up.
A full gas tank is much safer to be working around in a fab shop that one with very little gas in it.
Remember gasoline is not flamible in liquid form. -
What i am saying is your empty gas can that is full of vapors is just like a bomb, the less fumes the less chance of a mishap.
HiPerf360 wrote:A full gas tank is much safer to be working around in a fab shop that one with very little gas in it.
Very interesting.George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
true... liquid gas doesn't ignite, it's the vapors that burn, and burn they do... don't believe it? fill a plastic baggie with gas, throw it an a little fire pit... doesn't go whoosh, it soaks down and burns off slowly...It's not good, very fundamentally simply not good. - geolemon
i didn't know that about gas -- i'm sure somebody probably tried to teach me that before, but it never 'came across' my thoughts... i think u're right... lol... which is scary... lol... not that u're right but that i was actually making my life more dangerous instead of less dangerous.
far as oil changes go... wanna save cash, use dinosaur oil and do it every 3000 miles or 3 months if you do 10k miles a year or more.
if you're like my grandfather who does about 3000 miles a year... then do it every 6 months. everytime you change the oil do the filter too. oil "just sitting" in the crank case is the same as oil " just sitting" in a jar... it doesn't go bad. don't start imaginging that it does.
personally... i use synthetics -- full synthetics...
my change interval is 3 to 4,000 miles (i do every 3 months, and that usually works out to 3 - 4 k... if i go on a trip and pile on more mileage then i adjust my change interval to compensate). always change the fitler every time.
as far as what oil to use --- get a shop manual for your truck. people were telling me the older 318 shoud have 10-40 ... full of **** they were... its 10-30 unlessy our'e in a climate that never gets above 60 F or goes down to -20 F, in which case its 5-30. every car is different - find out what's right -- DO NOT LISTEN TO THE GUY AT AUTOZONE OR THE PARTS STORE! Oil weight is critical to lifter pump up and is relative to the main and cam bearing clearance.... in the days when clearances were 0.003 to 0.005 10-30 and 40 were the way to go... now that they're between 0.0005 and 0.001, it may be 5-20 or 5-30. use MFG spec grades.
as far as air filters --- every 15 k / or 1 year --- or whenever it gets clogged if sooner.The Artist formerly known as PoweredByDodge -
Actually it does go bad just sitting in the crank case, change it every six months at a minimum.
