RG6 Coaxial as component cables
gshisme
gshisme Posts: 1,038
This is the nephew of ghsisme.
After realizing the prices of component cables, I decided to make my own cables out of basic RG6 bulk coaxial cabling from radioshack, and gold plated connectors from parts express. When using the 2 meter lengths as interconnects for the connectino between the TV and the DVD player, I have noticed no differences in the picture quality between the custom RG6 cables and brand name component interconnects. They arent that bad looking either.
Pictures:
http://www.agcomptec.com/cables/b.jpg
http://www.agcomptec.com/cables/a.jpg
suds, suds and more suds!
Post edited by gshisme on
  • amulford
    amulford Posts: 5,020
    edited February 2006
    Good job. Try it with 3 Ghz sweep. You'll see a difference then.
  • mantis
    mantis Posts: 17,629
    Here's the deal,
    Once you have a solid 75 ohm connection, good quality video cables, nothing can go wrong. I also have not found better picture with high end video cables. It takes the sharpest eye to even find the difference. You can see it if you spend your time looking, swapping back and forth between the same thing/scene. But I don't think they are worth the asking price.
    What you made should work perfectly. As long as your connections are clean and perfectly seated in the connector
    Dan
    Dan
  • gshisme
    3ghz sweep?
