Rotel opinions
miner
miner Posts: 1,305
edited February 2006 in Electronics
I currently have a Rotel RC-1070 pre and RB-1070 amp (130 w/ch). I am considering upgrading the amp to the RB-1080 (200 w/ch). At only 70 w/ch difference will I see much sonic improvement? Damping factor on RB-1070 is 500 and on the RB-1080 its 1000. I have been told bass extension will be better. My speakers are B&W 804N and sub is B&W ASW800. I was looking to upgrade the pre to the Rotel RC-1090 but it is no longer available in the US. I missed out on the recent RC-1090/RB-1090 sale here or we would not be having this conversation. BTW, I handed my RT-20p down to my son and he is so happy (now he can get rid of the Blose 301s and Infinity bookshelfs).
Post edited by miner on
  • cfrizz
    cfrizz Posts: 13,415
    Go for it. More power is always a good thing!
  • janmike
    janmike Posts: 6,146
    Love the 1080 I have. I would like to have 200w all round in my HT.
    Michael ;)
    NORTH of 60°
  • mantis
    mantis Posts: 17,422
    Owning the 804's is Impressive all by itself. nice man nice. The sonic change is slight. The rb1080 is slighty warmer and more musical . With your speakers you will notice a difference. I 2 own Rotel in the RSP1068 and RMB1095. When I go back to using 7 channel, I plan on adding a RB1080 to run my mains.
    If you can get one in your house and demo them side my side, you may or may not need it. You may or may not like it. You have to really decide that.
    The comment more power is a good thing, well thats pretty true, it's better to have more and not need it then need it and not have it. So with that being said....
    Dan
    Dan
  • venomclan
    venomclan Posts: 2,467
    Hi miner,
    You absolutly need a better amp for the 804's. The FST midrange in the 804's alone will consume most of what your current amp will give. The Rotel 1080 will also be not enough for your 804's. The only Rotel amp that can mate with a B&W 800 series speaker is the RB-1090. Most 800 owners will not use Rotel, 800's require higher end amps.
    See if you can find a used Bryston, Classe, Earthquake, Krell...You will not believe the difference your 804's will sound. Check out htguide.com-B&W forum for some pointers. Good luck.
    Venom
  • dorokusai
    dorokusai Posts: 25,576
    Damping factor is a marketing number and means very little as far as a specification.
  • beardog03
    beardog03 Posts: 5,550
    you are a good father..!
    great speaks for the boy to cut his teeth on..!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • W WALDECKER
    W WALDECKER Posts: 900
    i owned a Rotel RB1080 and felt it sounded a bit compressed and you had to push it pretty hard for it to sound decent.it never sounded good to me at low listening levels.in my opinion there are better amplifiers in the same price range. audio is subjective by nature so your results may vary greatly.thanks....WCW III
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • 2+2
    2+2 Posts: 546
    I presume this is probably true but I would think that when comparing amps of the same brand where more than likely, measurement techniques will be the same, it probably does provide a good information regarding relative performance of the different amps in their line up.
    I had the 1075 before and it really could not handle the LSi 15s woofer at all. 1080 does it alot better. I would think your B&Ws would appreciate the power and current jump (the 1080 can muster a lot more current than the 1075 or the 1070)....but yea, if you have the deep pockets, go even higher....
    System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
    System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
    System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
    System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD
