newbie, think i have tweeter prob. in RTA 11T.
maxhawk
maxhawk Posts: 7
edited February 2006 in 2 Channel Audio
hey all, im new. been reading for a bit. inherited carver components system and RTA 11Ts. I believe with sl 2000 tweeter. tweeter makes a buzzing even with volume all the way down. I have carver 600w amp.
Post edited by maxhawk on
  • maxhawk
    maxhawk Posts: 7
    edited January 2006
    im replying to my own thread
  • danger boy
    danger boy Posts: 15,722
    edited January 2006
    post a picture of your tweeter/RTA 11's to be sure though.
    PolkFest 2012, who's going>?
  • maxhawk
    maxhawk Posts: 7
    edited January 2006
    thanks for quick reply. im sure its the RTA 11T and not the RTA11TL. It has "monitor series" written on metal tag. Also has particle board support under speaker instead of screw in feet. Silver coil tweeter.
    F1nut Posts: 51,794
    edited January 2006
    Swap the "bad" tweeter with the known good one. If the problem follows, you need a new tweeter.
  • halo
    halo Posts: 5,616
    edited January 2006
    Whether or not the tweeter is fried you are better off upgrading to the RDO194-1 replacement silk dome tweeters. Ask for Ken at Polk CS and mention that you are a Club Polk member to get a discount and free shipping.
    To test the tweeter, take it out and hook it up directly to you speaker wire / cable and play at LOW volume. If you still hear the buzz chuck the tweeter in the garbage or use it for a paper weight. :D
  • maxhawk
    maxhawk Posts: 7
    edited January 2006
  • maxhawk
    maxhawk Posts: 7
    edited January 2006
    yup, it was deffinitely bad by that test. will order silks tomorrow.
    I geuss that runs about 100$ or so.
  • george daniel
    george daniel Posts: 12,096
    Yep, mention that you are a CP member= 5% discount,great customer service though :)
