Where can I find the best priced plasma hdtv at?
tdogroeder
I am looking for a 42" - 50" size. And what are the best ones on the market for around $2000?
Yamaha RXV-757
JM-Lab Focal Cobalt 816 S's, JM-LabFocal Cobalt CC 800 S, FXi3's, RT15's & PSW 303
Post edited by tdogroeder on
You will not get into a 42 let alone 50 for 2 grand. But if you looking for a great plasma that don't cost alot, then check out Panasonic. they make the very best budget plasmas on the market.
Go to your local Tweeter
DanDan
Sams Club has an Akai 50" HD plasma for $1999
Edit: It is the ONLY one on the market for that price.Vinyl, the final frontier...
I'm a Panasonic fan as well. Bought my RPHDTV over 5 years and it still looks fantastic. You may be able to go DLP for $2000 (but that may be tight), but you won't get the greatest plasma at for that. Check Sears (on-line), they seem to have good prices on TVs.Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64 -
The pro-level Panny's come in at $2k, but they have no tuner, no PIP, no DVI or HDMI, no speaks, no stand or mount and you'll probably have to pay shipping form an on-line source.
I don't need most of that stuff, so I'm getting one with a wall-mount and shipping. I'll pick up a DVI card once the funding builds back up.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
i got mine from onecall.com, but they are local here - so no shipping for me. good prices though. Good luck
Jason2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
Source(s): Computer and Denon 2910
Amp: Parasound HCA-1200II
Speakers: LSi9s - Vr3 Fortress Mod -
Check out Panasonic...................................it's a very good option just look for some reviews..........they will help u take a decision
