Kimber 8TC/LSi9-LSiC
disaeur
Post edited by disaeur on
I gotta ask why you want bare wire at the speaker end? The problem is not it fitting but it turning green over time. Oxidation is going to happen sooner then later with bare wire. This is the best reason to go with terminated ends. It protects the ends from this.
Also trying to manage 8tc bare sucks. I suggest you get the post master spades or banana jacks from Kimber pre terminated.Even trying to terminate the ends yourself can be a suck **** task.
DanDan
I agree with Dan. The 8TC has a cumulative 9awg conductor per side, that's pretty thick...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
i'm getting 3 cables from a co-worker who needs some quick cash. he terminated one end with WBT 0644 bananas and and was under the impression that bare wire is the best contact method.
While generally a bare connection is the best, most people opt for the convenience of a connector of some type. I seriously doubt you'll ever hear a difference...
Degradation comes into play with some soldered connections, stay away from those; pressure or crimp connections are usually best.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
I like the banana jacks.
SuperDave
Yamaha RX-V992
Panasonic DVD-A310
Sony XBR 27"
BrightHouse DVR
Polk LSi25 Fronts
Polk LSiC Center
Infinity RS1 Rears
Monster THX CablesSuperDave
Yamaha RX-V992 (Center,Rears)
Adcom GFA-5500 (Mains)
Denon DVD-1920
Mitsubishi 40" LCD
DirecTV DVR Whole House
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables -
I like banana's too, especially if you have a rack that is difficult to get behind.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
To answer your original question. I have 10 guage unterminated to my LSi7's and there is still a little room. I would say the LSi series will take about 8 or 9 guage wire.
