Monitor decisions. Floor vs bookshelf. Sub size. Help me decide.
Hoop
Hoop Posts: 28
edited February 2006 in Speakers
Im building a new HT setup in a new (dedicated) room in the basement. I would say that 95% of the use will be either HT or XBOX. My room is about 14x15x8. No windows and only one door. In case it matters, I have a Sony STR-DE695 receiver.
I'm kind of working with something like a $1-1.5k budget. I'm think that this is putting me in the Monitor line, with the possibility of RT line using bookshelfs for fronts.
Assuming that I go with the Monitor series...
Since I am primarily using the setup for HT, I would like strong center performance. Is there enough performance differnce between the CS1 and CS2 to warrant an approximate $120 price difference? That's one possible upgrade.
For subs, is there a similar difference between the PSW10 and the PSW12? I don't think my room is too big to fill easily but is 50w enough? Again this is about a $150 upgrade.
Normally I would opt for a floor standing speaker. I was thinking Monitor 60. However I can save about $160 by going down to the 50 and a whopping $260 (almost half the price) by going down to the 40 bookshelf. Of course then I would have to get stands ($100?). But that might allow me better placement (height). I would think it would decrease bass performance, but that could be offset by the PSW12?
For rears, I'm wanting in-wall. I think that the RC55is would be sufficient for my needs.
It's my understanding that everything I've mentioned is 'timbre matched' as much as possible.
So, 60s and PSW10 vs 40s and PSW12. Which seems like a better option. There are marginal (if any) cost differences.
CS1 vs CS2. Worth the upgrade? Does it make any difference what the front/sub decision is?
Finally, is there any where to get discounted prices on Polks? It seems like they have tighter price control than Sony. When you see things on pricegrabber like '7 prices from 199 to 200' you have to wonder.
Thanks for your help as I am a noob at this (you should see the ghetto speakers I have now). Somehow I got hooked on the idea of Polks (great sound reputation and they look so nice).
Post edited by Hoop on
    VR3 Posts: 29,394
    edited January 2006
    Id get some bookshelfs from the monitor line...
    a SVS Subwoofer : PB 10 - youll thank me later - www.svsound.com
    Everything else sounds good
    HT/Gaming = A good sub. One that can hit below 20hz.
  • BjornB17
    BjornB17 Posts: 752
    edited January 2006
    The Monitor 40s are basically just a bookshelf version of the Monitor 50s. I guess you can figure out whether or not buying the stands and all that is worth it to you. Either of them is a great speaker. I love my Monitors!
    But, you could also go for a basic RTi setup. You could get a pair of RTi4s (which cost LESS than the Monitor 40s and are equal or better in performance), and you could get a CSi3 which costs $100 less than a CS2. I agree with the above post about getting the SVS sub.
    KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
  • halo
    halo Posts: 5,616
    edited January 2006
    If you want to go really inexpensive go for the R15's when Fry's - outpost.com - has 'em on sale for $49 a pair.
    Want towers? R30's @ $39 each or R50's @ $89 each when Fry's is running sales.
    Pick up a CSi25 (I think they were just on sale for $69)
    Get a SVS PB-10 $429, or 25-31 PCi $549.
    I'm running FR,FL,SR, & SL R15's + CSi20 + SVS 20-39. In a word - awesome! Three words - awesome and inexpensive! :D Best of luck - let us know what you decide :)
  • tbPAF
    tbPAF Posts: 5
    edited January 2006
    I have the rti6, csi5 and svs pb10-isd. Very happy with this setup. The sound is crisp, clear and with a great bottom end down to 20hz. Get the SPL meter from RShack or svs and make sure you get the volumes leveled.
    Equipment: RTi6, CSi5, SVS PB10-ISD sub, speakercraft 6.5crs ceiling surrounds, Onkyo NR801 receiver
  • Maestro
    Maestro Posts: 92
    edited January 2006
    I have a dedicated HT room similar to your dimensions and I use the PSW12 which handles the room very well. It's not overpowering, but it will get the job done. With the combination of speakers you plan to use, the PSW12 would make an excellent compliment to a well-balanced HT system. I've had my HT now for a little over 6 months and I still enjoy it like I just got it yesterday. AND I got it all at a killer price!!
    _________________________
    Main: Polk R50s
    Center: Polk CSi3
    Surround: Polk R30s
    Rear: Polk R15s
    Sub: Polk PSW12
    Cherry Wood Edition
    Whirlwind Cables/Connectors
    Harman/Kardon AVR635
    Harman/Kardon DVD 27
    Sony RDR-GX300 DVDR
    Sony Bravia 40" XBR1
  • BjornB17
    BjornB17 Posts: 752
    edited January 2006
    Let me guess, you got most of your speakers from outpost.com when they have the amazing deals on r series speakers?
  • Maestro
    Maestro Posts: 92
    edited January 2006
    Yes and no: Frye's store location and Crutchfield.
    Main: Polk R50s
    Center: Polk CSi3
    Surround: Polk R30s
    Rear: Polk R15s
    Sub: Polk PSW12
    Cherry Wood Edition
    Sony RDR-GX300 DVDR
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    Hi.
    I have the same problem....is the monitor 30 the correct surround speakers????
    Personally I believe YES. But other opinions would be great. Thanks
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
  • crazy
    crazy Posts: 443
    They're exactly the same???!!! So essentially the Monitor 50 is a cooler looking (depending on if you like floor speakers or not) Monitor 40???!!! I am shocked :eek:
    So what's the difference between the Monitor 50 and 60 then?
    Distant Dream - A New Beginning
    www.distantdream.com
    (Now also available on iTunes)
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    the 60's boast an additional 5 1/4" driver...
  • BjornB17
    BjornB17 Posts: 752
    Not exactly the same but very close. I've listened to both and you cant really tell a difference. The cabinet for the 50 is slightly bigger, but it has very little effect on sound, atleast to my ears. Keep in mind they both use dual 5.25" drivers and the same tweeter.
    Thes 60s are different because they use 3 5.25" drivers intead of 2. I think all of the 5.25" drivers in the 30s, 40s, 50s and 60s are mid-woofers. The 70s use 4 6.5" drivers, two of which are midrange and two of which are woofers.
  • zombie boy 2000
    sorry to hijack this thread..
    hey bjorn, have you noticed any difference in the output of the drivers in the 70's when adjusting the crossover?
    seems like the higher i set the crossover on my receiver, the more "similar" the four drivers become
  • crazy
    crazy Posts: 443
    And I suppose that's what makes it a little fuller than the 50's? I auditioned both and found little difference between those 2 except that the 60's sounded a little fuller than the 50 - again I could have been biased by the fact that the 60's are a little bigger and more expensive :-)
  • BjornB17
    BjornB17 Posts: 752
    I think the 70s use a 2.5-way design (again i could be mistaken, im not a Polk engineer:)) in which all 4 drivers are crossed over at 2.6 khz, so they should all play up to that range, however, the top two drivers will only play down to a certain point, while the bottom two drivers will play to lower frequencies. So if that is true, it will make sense that they should all sound more similar at a higher crossover, since they are in fact probably playing the same frequencies.
    Overall im very happy with the Monitor series speakers. They are very bright sounding, but they dont sound harsh. They dont put out much bass, but with a good subwoofer they can balance together very nicely. I got my 70s for $240 each at CC (effictively, after selling the 'free' PSW10, and $205 for the CS2, and $100 for each of the Monitor 30s. CHT-12 sub cost me $280. Got them all at Circuit City. The salepeople there act like used car dealers (i know the tactics since i used to work at CC), and they will tell you that they can't negotiate the price or anything, but just haggle with them long enough and they will budge. I kept the audio/video manager tied up for over an hour and he finally gave in :)
  • zombie boy 2000
    good to hear about the lads at CC.. since i'm planning on making my way over there soon to purchase some 30's
    retail $200-- any suggestions on what to aim for?
  • BjornB17
    BjornB17 Posts: 752
    If you're going to get the 30s, you can get these:
    http://www.tweeter.com/product/index.jsp?productId=2124916&cp=&keywords=polk&searchId=10517252646&parentPage=search
    Polk T20, which is the same speaker as the Monitor 30s except for a few costmetic changes. You also get free shipping. Might take a couple weeks to arrive because of backorder though. either way, you can save the $70 :)
    As for circuit city, they usually wont negotiate unless you're making a large purchase, such as $500+. I got my 30s about a week after buying the other 3 speakers, so i lost my negotiating power since they weren't at risk of losing a large sale,but if you're buying multiple speakers, they should be able to work with you.
    When my brother bought his new setup, he was able to get his main towers for about 25% off each, along with a free center channel and two bookshelves for surrounds as long as spent at least $200 on a subwoofer. So he got a Velodyne CHT-10 which was on clearance for $200 :D and got all the other speakers for an amazing price.
  • zombie boy 2000
    brilliant... and absolutely no difference, eh?
    this seems to be far and away the best option
    good looking out :)
