RT2000p
Norm E. Dickey
How can I come by a schematic for the lower driver array x-over? Mine do not function line level or through the sub-amp. Drivers are fine, so is the wiring from the x-over unit. Thanks.
Welcome to my home, enter of your own free will and leave a bit of the happiness that you bring. -D
Post edited by Norm E. Dickey on
Hello Norm,
When you say the lower drivers, do you mean the two 8" drivers that are powered by the built-in amplifier?
Regards, Ken Swauger -
Hello Ken,
That is correct, the twin 8" drivers.
I have some experience with surface mount tech and would like to try to fix the assembly myself. To do so, I would need the schematics. OR I may scrap the amp assembly and install a non-OEM crossover and run the entire speaker from my amp in a bi-wire config. I'm running 250W/RMS per channel, so I don't see there being a power issue. I would then need the crossover point to choose the correct x-over.
I checked both amp assemblies, the fuses & transformers are good and I don't see any board burn. The previous owner wasn't sure when/why both speakers failed. (That info would've been nice.) Thanks.Welcome to my home, enter of your own free will and leave a bit of the happiness that you bring. -D -
Hello Norm,
Thanks for the reply, if you'll telephone me at 1-800-377-7655 extension 891 I can get your address and mail you a copy of the RT2000p amplifier schematic.
Regards, Ken -
Necro-posting and spamming... Nice.
