Halo A23 amp High Temp led?
disneyjoe7
disneyjoe7 Posts: 11,435
edited December 2005 in Troubleshooting
Hello all, Merry Christmas.
I use 2 of these amps they are bridged for my Rti150 front speakers. One amp is still working both the HiTemp led is a little on (not really bright just half bright).
Is this a OH **** problem?
:eek:
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
  • amulford
    amulford Posts: 5,020
    Sounds like you're just warming up! :p
    Sorry, just had to... FWIW, if the hi temp isn't supposed to be on, I don't think it should be. Have you called anyone about it?
  • Emlyn
    Emlyn Posts: 4,630
    Not a problem. Just a warning, at this point. Have you tried running them in biamp configuration rather than bridged and see if the results are the same?
  • disneyjoe7
    Will ok just is what I have done so far. I swapped the amps the problem followed the amps where on for like 5 mins, light on amp still working? Listening a little down not loud, amps aren't hot.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Emlyn
    Emlyn Posts: 4,630
    The problem with bridged mode on the A23 is that it's only stable with 8 ohm speakers at high output levels (it sees an 8 ohm speaker as a 4 ohm load). When I had a pair of RTi150's, I suspected that they were drawing more current than a typical 8 ohm speaker would. Those woofers appear to be the hard section to drive on those speakers, and I wouldn't be surprised if their impedance dips closer to 4 ohms than 8 ohms. When the speakers dip to 4 ohms, the bridged A23 amplifier actually reacts as if it's driving a 2 ohm load. Very few amps are capable of doing that for extended periods. That's why I'd suggest using the amps to biamp, that way their output devices are more capable of driving lower impedance loads without over heating.
