Should I go with LCD or CRT??
ND13
ND13 Posts: 7,601
edited December 2005 in Electronics
I'm debating whether or not to get a flat panel LCD or another, larger widescreen HD tube tv.
I can get a 32" flat panel or a 34" tube for the same $$$. The convenience and the style of the 32 would be nice, but it would only be a 2" upgrade over the 30" ws hdtv I have now and have had no problems at all with. I'd get a 37" if I could talk the wife into the $$$ difference ($600).
The 34" ws hd tube would be a 4" upgrade and the advantages of the tube out weigh the depth and weight issues, imo.
Anyways, the lcd is a Westinghouse, which I'm sure is made for them by someone else. The tube is a Toshiba. I'll be upgrading a Philips, it will end up in the bedroom, I guess. The living room entertainment center will not hold it.
So, if the size and weight issue aren't as big of an issue as they are to most people, which way would you go?
Please remember.......I'm not a big HT hobbyist, it'll be used for sports as much as movies and such.
"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
Post edited by ND13 on
  • madmax
    madmax Posts: 12,434
    If size and weight is not a difference I think I would go with the tube over the Westinghouse LCD. I think you will end up with better reliability and repair possibilities. On the other hand, I don't know if I can say that because in warranty they would fix the tube set (big hassle) or replace the LCD and after warranty you wont want to pay the going price for repair of the tube set anyway. Repair costs are outragous and the smallest thing could cost you a $100 trip charge, a $120 parts cost and $150 repair charge. That would be $370 maybe and you probably wouldn't pay it anyway because over a year later you would find a better tv for $370. I guess I just ended up thinking the LCD would be a better choice. Another plus of the LCD is that if it goes through life with no problems then it will be easy to put anywhere in the future when you decide to upgrade.
    madmax
    Edit: For sports watching make sure if you go with the LCD that it doesn't blur when the camera pans. Some of the older slower ones had this problem.
    Vinyl, the final frontier...
  • opus
    opus Posts: 1,252
    Nd, I sure you know but a recent Sound and Vision reviewed a Westinghouse LCD. Not sure which size( mag is at work) but it may be worth looking up. Happy Hunting
    The Flea rig
    Hitachi 50VG825 LCD
    Rotel RSP 1066 (pre) :)-flea market
    B&K St-202 (mains)-flea market
    Carver M 200t (x2) (center and surrounds)-flea market
    Blu-Ray..PS3 (dvd player)
    Polk RTA-11t-flea market
    LsiC, Fxi30's
    Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
    Behringer Feedback Destroyer
    -flea market
    AudioAlchemy DDE v1.0 DAC-flea market
    Cambridge Audio Azur 640 CDP-flea market
    Signal Cable and Kimber Kable
  • PolkThug
    PolkThug Posts: 7,532
    If you like picture quality, go with CRT.
  • ND13
    ND13 Posts: 7,601
    I've leaning towards the tube, mainly because of the extra 2" screen size. I'm gonna work on the wife to let me spend the extra for the 37" lcd. It's a Westinghouse too, but it's the new 1920x1080p model. Over 2 million pixels.
  • amulford
    amulford Posts: 5,020
    I have a problem w/ the lcd's. they can't keep up with the faster motion. IMO, CRT all the way...
  • mantis
    mantis Posts: 17,355
    Agreed, CRT is a better looking picture overall.
    Dan
    Dan
  • cfrizz
    cfrizz Posts: 13,415
    Noel, I would also go with the CRT. I have read about so many problems with the newer tv's that to me, it just is not worth it.
    You will most likely have the CRT for eons & never have to get it repaired, whereas a LCD ect. is a complete question mark, with a big helping of hope thrown in that it lasts.
    Go CRT, outstanding picture with excellent reliability!
  • BjornB17
    BjornB17 Posts: 752
    why not get a projector, which will probably cost about $500 and a $100 screen? That's what i did and now i have an 85" picture in my small room.
    KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
  • danger boy
    danger boy Posts: 15,722
    tube... it's what everyone is hot for right? tube pre, tube amps... tube CDP.. now get your **** a tube TV. :p
    JK! you really can't beat the picture quality of a CRT. colors, brightness, contrast. etc.. CRT's have been around for ages.. I think they've pretty much worked out all the kinks in em by now. :D go for a 36" or larger if possible.
    PolkFest 2012, who's going>?
  • ND13
    ND13 Posts: 7,601
    The largest widescreen is 34" in a tube. I wish they'd make one in the 40" range, but I don't even think they are looking into it. Actually Samsung has come out with a slim line, which is not as deep as the norm, but they've priced them too high imo.
    I thought that RCA had made a 38" widescreen a few years back, but I can't find any now.
    I just did a search and RCA did make a 38" HD Widescreen. You want to talk about salty. :rolleyes:
  • Ferres
    Ferres Posts: 310
    Most TV manufacturers are moving away from crt's and just subcon them to China. A lot of the newer Sony tube TV's have defects with their flyback. Flat panels will be the mainstream in a couple of years so support for crt's will diminish over time.
    Newer generation lcds can keep up with the 'action' nowadays.
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    So athletes have been trained to run slower? That explains why the games run over 3 hours regularly.............
  • TheReaper
    TheReaper Posts: 636
    Look at the Westinghouse LCD in a store, to see if you can live with the color. I saw one at BB, it had pinkish reds (you might be able to adjust it to look better).
    The Westinghouse 1080p LCD is very interesting if you are going to hook it up to a PC.
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • amulford
    We've got a 34" WS CRT in the attic with the video games hooked up to it. Friggin nice TV.
  • faster100
    faster100 Posts: 6,124
    yeah Noel, be like everyone else and get a CRT, :D or try a Lcd and be done with it.. small screens, heavy **** to move with a tube tv, we have a RCA big screen and we want a 42" plasma or lcd widescreen and recover some living space, they look cool and the ones ive seen in stores look nice to me.
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • ND13
    ND13 Posts: 7,601
    Aww screw it!!! I'm just gonna keep waiting and spend the money on the Stang instead.
    It's gonna need some tires, a window motor, flush, wheel bearings, etc, etc. Just some TLC, all minor ****.
    I'll get a tv when they come down some more. That 37" is what I really want and they are half of what they cost this time last year, so they'll keep coming down. Maybe by the time that my tax return comes back, they'll have gone down another few hundred.
    Thanks for all the replies.
  • MacLeod
    MacLeod Posts: 14,358
    Personally I like LCD's best of all. I really like their pictuire quality and the fact that you never have to worry about burn in. My favorite is the Sony LCD. Their 32" goes for $1700 right now at CC. That would be the one Id get if I were in the market.
  • Gaara
    Gaara Posts: 2,415
    Never seen a LCD to rival my 34HS510, only thing that comes close is the sony 40in xbr lcd. Then again I've spent over 30 hours tweaking this thing in the service menu, so I am quite satisfied with the picture to say the least
  • shack
    shack Posts: 11,154
  • amulford
    Yeah, you forgot to mention the SR6500's for the Stang....
  • ND13
    ND13 Posts: 7,601
    I've got the MMC6500s that I had in the Chevy. I didn't let those or the amps and sub go. I've got my car audio guy getting me a price for the SRs. He got me the Momos for $225 installed, which I guess was a super price. Maybe he can get me the Srs for $400-450.
  • madmax
    Yea! Why spend money to watch the action on TV when you could be creating your own???
    madmax
  • PolkThug
    EFF YEAH!
  • ND13
    ND13 Posts: 7,601
    Tires are being put on today. It already has a decent head unit, KW KDC-X615, Excelon series. Hopefully I won't need to change it out. Then I'll have to decide on going with two 10s or one 12 in the trunk.
  • Ferres
    Ferres Posts: 310
    It's cool to wait a while. Who knows what will be available in 2006 :)
