Home Made Cables
okiepolkie
okiepolkie Posts: 2,258
I'm still getting my learn on about audio and video interconnects, so play like I don't know anything about cables at all(which is only part true).
I've read this thread about RG59 vs RG6, but I'd like to know a little more.
What types of cables are used for the following application
Coax: RG59-CATV & OTA RG6-C CATV, OTA, DBS
What other uses do these have?
Component Video:
Digital Coax:
S-Video:
Composite:
Audio Interconnects:
I will be using this compression coax tool, but I will learn to solder if this won't work for all applications.
As always, thanks for the help.
Zach
Tschüss
Zach
Post edited by okiepolkie on
  • mantis
    mantis Posts: 17,563
    edited December 2005
    You can use rg59sd or rg6 for all listed. Depending on the level of system your installing, rg6 works fine. I don't like it for analog interconnects uness your using a multichannel multiroom amp powering inwall background speakers that no one is going to cridically listen it.Then I see no reason not to make custom length cables for this.
    Ialso perfer rg59sd for video feeds stranded. it's easier to work with and from my experience I haven't found other cables at given lengths to perform better for video.
    rg59sd also makes for killer custom digital coax cables.
    Dan
    Dan
  • okiepolkie
    Dan,
    Thanks, as always, for the help. What type of RG6 should I go with? I see it with a /U and without. Also, what type of shielding would be best? I'm going with the Parts Express right now, and I see aluminum tape/braid and Quad Shield.
    BTW, I couldn't ever find the coax tool you referenced, so I thought I would try the one from PE out for now. I can always switch next year.
    Zach
    Tschüss
    Zach
