Choosing the right speaker
dsm213
dsm213 Posts: 1
edited December 2005 in Troubleshooting
Currently I have the Harman Kardon DPR 1001. All the stats are below. What would you recommend to match with it. I'm looking for something I can attach to the wall so I was thinking either RM10 or RM6800. Would the RM6900 be overkill for a low powered unit.? Any help would be apprecaited.
Continuous Average Power (FTC) Per Channel : All Channels: 50 Watts per channel @ 8 Ohms, 1kHz, 0.19% THD
Power Output per EIA 490A : 65 Watts x 7 @ 8 ohms
Input Sensitivity/Impedance Linear (High-Level) : 200mV/47k ohms
Signal-to-Noise Ratio (IHF-A) : 90dB
Surround System Adjacent Channel Separation :
Dolby® Pro Logic® I and II : 40dB
Dolby® Digital : 55dB
DTS® : 55dB
Frequency Response at 1W (+0dB, –3dB) : 20Hz – 22kHz
Transient Intermodulation Distortion (TIM) : None
Negative Feedback : None
http://www.harmankardon.com/specifications.aspx?cat=REC&ser=&prod=DPR%201001&sType=H
