Improving SQ on a TV
Early B.
Early B. Posts: 7,900
edited December 2005 in Electronics
Was wondering if anyone ever experimented with improving the SQ on a television. Most of them sound terrible. Anyone ever replace their TV's speakers with higher quality ones? How about using a 2.1 computer speaker system?
"God grooves with tubes."
Post edited by Early B. on
  • mantis
    mantis Posts: 17,380
    Whats wrong with the tv speakers? I mean when you want higher sound quality the natural thing is to go with a Audio system.
    But no I don't know anyone who replaces there tv speakers with higher quality ones.It seems you have a need for this.
    Dan
  • BIZILL
    BIZILL Posts: 5,432
    would that be considered "the poor man's home theater setup?. 2.0 surround. or get an svs pc-ultra and create 2.1. actually, i'm sure it might possibly help sound just a teencie weencie bit, but without higher amplification, it would all be for naught.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • LiquidSound
    LiquidSound Posts: 1,261
    I'd certainly try it. Why not, if you can do it cheaply. If it doesn't work, take the drivers and stick em to your neighbor's car.. :D
    Two Channel Main
    Receiver - VSX-54TX
    Mains - Csi40's
    Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
    "If you could put speakers in a needle, I'd never see him again..." - My Girlfriend
  • Early B.
    I'm not referring to the main TV. Most of us can use our audio or HT systems.
    Let's say you have a 27" TV in your bedroom. Just wondering if you can hook up a $40 2.1 powered computer speaker system to improve the sound.
    Nevermind. Just thought about it -- even if it's possible, you'll need a wireless remote to adjust the volume. That'll probably make it cost prohibitive.
  • gregure
    gregure Posts: 871
    Not only that, but most TV's only have audio outs, so you'd still need an amp to run two speakers. You could perhaps accomplish it with a mini-plug (RCA to headphone jack) from the TV to computer speakers as most of them have amps in the sub, but it's really best to do a stereo receiver with two good bookshelf speakers. That's really the only way to upgrade TV speakers.
    That said, I noticed a real difference on my Sony TV (Sony Tubes actually have pretty decent speakers) speakers hooking up some Audioquest Sidewinder interconnects from the cable box to the TV. Beats the **** out of those horrible, thin-black-wire cables they throw in. I can't even turn my TV up half-way without it being too loud (only use the TV speakers when it's late).
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
  • Gaara
    Gaara Posts: 2,415
    You could always use a minisystem for around $100 to improve the sound quality. My first system consisted of a sony $150 mini system, a 20in apex with s-video, a ps2, and a jvc dvd player. Sound quality was much improved with the minisystem in there. Just find one with audio inputs and your good to go.
    Jared
  • Early B.
    Gaara wrote:
    You could always use a minisystem for around $100 to improve the sound quality. Just find one with audio inputs and your good to go.
    Good idea. I have an old mini system in the basement that would work well. It has a remote, too, so I can program it into my other remote and adjust the volume. Zero cost. Cool.
  • steveinaz
    steveinaz Posts: 19,545
    Does this TV have audio out or external speaker connections? Another option might be running the audio out from the cable box if you have one.
    I bet good 'ol Rat Shack has some kind of thingamajig that you could run your cable connection into and get audio out connections--RS is a great place to look for off-the-wall stuff...
