Is DVI better than component???
drew spelts
drew spelts Posts: 310
edited November 2005 in Electronics
Wonering if the gains you could possibly receive by using DVI capable DVD player are worth it on a 32inch HD CRT Sony VVega TV. Or if it would be almost unnoticable compared to component video coming out of say a denon 2900. Basicly the Denon 1910 vs. 2900. Please give any and all opinions, thanks.
Harman Kardon AVR635
RTi10's Up Front
CSi5 Center
RTi6's Rear Surround
Furman RA-1210:rolleyes:
Post edited by drew spelts on
  • mantis
    mantis Posts: 17,561
    If a tv and dvd player or cablebox has DVI out/ In then yes this is the best way to go. On your 32 inch tv, it will be harder to tell the difference.
    If you have component already, stick with it and spend your money elsewhere.
    If you upgrade to a larger HDTV then DVI or HDMI does have a noticable better picture.
    I still like component.
    Dan
    Dan
  • BIZILL
    BIZILL Posts: 5,432
    dvi = all digital. component = digital to analog
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • BrentMcGhee
    BrentMcGhee Posts: 548
    nuff said :)
  • Willow
    Willow Posts: 11,257
    I tried the DVI/HDMI, I didn't like that it left a lil line on the top of the screen which was white. I use comp and the price dif in cables for the quality, not worth it IMHO.
  • BIZILL
    BIZILL Posts: 5,432
    SOUNDS like a prob with dvd player or tv. and like mantis said, almost pointless without a bigscreen to use dvi.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • shack
    shack Posts: 11,154
    There are quite a few discussion across the net about DVI/HMDI vs component. The consensus seems to be...it depends. I have tried both with my Denon 1910 and Panny 53 in HD RPT and I could tell little difference. Since I borrowed the DVI cable I stayed with the component as the cost was not worth the difference (if any).
    billbillw Posts: 7,798
    Actually with the CRT set mentioned in this thread, its Digital to Analog within the TV anyway. So there is very little advantage to using DVI with CRT sets. It all depends on the quality of the output of the DVD player. Some players do better on DVI, while others have better output on the Components. Very few players have equal quality output on both.
  • Willow
    The quality of the pic on my TV with the DVI/HDMI was not enough to justify the cost dif.
    Mine was set up DVI/HDMI from the HD cable box to my 32"lcd.
    I say if you have comp cables lying aroud as I did use that you can use the cash towards an upgrade which will make a real dif.
  • BIZILL
    BIZILL Posts: 5,432
    somewhere along the signal's path it'll always become analog at some point. but keeping it digital as long as you can is theoretically best. but as you say, for a smaller crt, even high def, it's not going to make much of a difference.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • kberg
    kberg Posts: 974
    I'm using composite now, and don't believe I'm able to use a DVI/HDMI cable even if I wanted to, since the Comcast Motorola boxes aren't yet setup to support it.
    If anybody out there has Comcast and is using a DVI/HDMI cable, please let me know!
    Mains: polkaudio RTi70's (bi-wired)
    Center: polkaudio CSi40 (bi-wired)
    Surrounds: polkaudio FXi30's
    Rear Center: polkaudio CSi30
    Sub: SVS 20-39 PC+
    Receiver: ONKYO TX-SR600
    Display: JVC HD-56G786
    DVD Player: SONY DVP-CX985V
    DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
    Remote: Logitech Harmony H688
  • snakebitten
    snakebitten Posts: 94
    Do you think the dvi from the dvr cable box to a 46 w/s hd projection tv would make much of a difference over the component cables? The reason I ask is because charter cable doesnt have the dvi working on the box I have now but I can get on a waiting list for a dvr that does.
  • PolkThug
    PolkThug Posts: 7,532
    ding! ding! ding!
    For example, a DVD player with a superior interlacer with component output will kick the carp out of the DVI DVD player with the inferior interlacer. (ie Denon vs. Samsung)
  • BIZILL
    BIZILL Posts: 5,432
    SUCH is the case with my oppo. it's dcdi chip upconverts signal only through dvi. component is not anything to brag about. all i know is when i had my cox cable high def box, i had it hooked up via component and then went to dvi and saw no gain what so ever. did not exactly do a side by side, but with high def, there wasn't much to look for. all is clear as can be.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • snakebitten
    Thanks bizill, thats what I wanted to know.
  • BIZILL
    BIZILL Posts: 5,432
    glad we all could help.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
