What would help the most???
millerman 3732
Business has been pretty good these past few months and I have a little extra cash to do some upgrades on my ht and I wondered what you guys thought I should upgrade first. I'am looking at upgrading my current reciver an Onkyo TX-SR 600 (6.1 at 80w per channel)to a Denon 3806 ( 7.1 at 120w per channel) or upgrading my sub a Klipsch KSW 15 to a SVS PB12/2. Both upgrades are around $1200 each and I just wanted to see what guys think will give me the most improvment for the money
Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Post edited by millerman 3732 on
Kinda leaning more toward the denon myself, but I thought I'd see what some of you all thoughtCasey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Polk Signa-1 Surround bar -
The Denon. The new avr3806 is awesome as expected.
The Klipsch sub isn't a bad one. I used to Install them.
DanDan
The Denon!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I would also lean towards the Denon.
ChrisReceiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt -
Mantis, not to get off topic, but about the Klipsh sub, a couple off weeks ago I took the woofer out of the sub box and there where 2 to pieces of yellow foam inside the box and it looked like they had been just thrown inside. I got the sub from a local dealer that was using it for his own ht and I was wondering would the foam have been put in from the factory or maybe added laterCasey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Well as far as the most impact to your home theater I would have to say the SVS. The change will be felt on almost every movie that you play.
I would get the SVS, then an amp, then a pre/pro. Get out of the receiver game and go separates. (if your Onk has pre-outs for all channels anyway)
Just a thought in case the next few quarters are good to you as well...
Denon 3806...........go for it bro! You will enjoy smoother overall sound right away.
http://www.polkaudio.com/forums/showthread.php?t=34121
GatorTheatre System 5.1
Sumsung HP-S5053 plasma
Receiver Denon AVR 3806 Pre/Pro
Parasound HCA 1500A amp (front L/R)
Parasound HCA 1000A amp (centre)
B & K AV5000 amp (bi-amp + surround)
Dynaco ST70 tube amp (Herbie HAL-O9)
polkaudio Lsi15 (Cherry) 2-channel
polkaudio Rti8 Front (Cherry)
polkaudio Csi5 Centre
polkaudio Rti6 Surround
polkaudio PSW1000 Subwoofer (Cherry)
Original A8T CD
Pioneer DV-275 DVD Player
MONSTER CABLE MP-HTS3500MKII Powercentre -
man created visa for a reason.....
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
Ok, dude here is what you do...
Go to circuit city online and pick up a Onkyo TX-SR 702 on sale for $524.99 (after $275.00 savings). This will give ya 100 watts instead of 80, but more importantly give you line level pre-outputs. The go out and buy a seperate amp for your fronts. You should be able to find a good two channel amp for under $1000. I bought the Niles SI-2125 from crutchfield.com for about $750 and whas happy with it. I also have a SVS, but dont feel it added as much to my system as a seperate amp, especially if you cross over your fronts around 60hz or lower. And if you got enough money left over, go ahead and buy another amp two channel amp for the center channel. Then you can use the Onkyo to power the surrounds.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture. -
The SVS would be a nice upgrade over your kilpsch, but that would be my second choice.If...
Ron loves a film = don't even rent. -
Ron-P wrote:Don't go and waste $1,200 on another receiver when you can get better sound for less by going with separates. I bought my Outlaw 950 7.1 pre/pro for $400 and 5 Adcom 2-channel amps for under $600. QUOTE]
Yup, i totally agree. Also if you can buy used, you might be able to find a pre/pro and amps for under $1500.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Separates all the way. What type of speakers are you powering? How large is your room and how far away do you sit from your mains? What dB level do you tend to listen to? Answer these and we can help you out more.
The foam is in there to get the subwoofer to its apropriate internal volume. Don't remove it.
I third, fourth, whatever the seperates.
You might also be able to find a used B&K receiver in the price range you are looking in which would own the Denon and Oinker in every way possible.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
If the sub is sealed, by all means take the foam out. That will up the Q which means a less steep rolloff = GOOD. If it's a ported design, I wouldn't touch it as it "might" help obtain the proper tuning.
Mazeroth wrote:If the sub is sealed, by all means take the foam out. That will up the Q which means a less steep rolloff = GOOD. If it's a ported design, I wouldn't touch it as it "might" help obtain the proper tuning.
And I've always read you want some kind of fill in your subs, it helps with standing waves and absorbs any high frequency info that makes it past the crossover. It also "tightens" the bass.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
I' ve been looking for ways to try and go with the separates like many have suggested but I just don't have the room to add any amps right now since my ht is also my living room. About 1 1/2 years ago I replaced my 46'' rptv with a 60'' lcd rptv and had to take out my component rack so all my gear has to fit in the T.V. stand and I don't have any where to move the rack that wouldn't require a major rewiring for the speakers and video cables.Although I'am sure your all right about separates being the way to go, until a can build a media room or the kid moves out i'am afraid i'll have to stick with the just a receiver for nowCasey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Yes, I meant to say lower the Q
As far as stuffing, if you have a sealed sub using polyfill can increase your theoretical box size by up to 20%. As far as using some type of sound absorbing foam on the sides, most of the threads I've read on the DiY speaker sites say it's a waste of time, and more importantly, it decreases the size of the box. If you're using a woofer (non sub) up to say, 500hz, I could see using some foam. Aside from that, I think it's a waste. -
Then go for the Denon!millerman 3732 wrote:I' ve been looking for ways to try and go with the separates like many have suggested but I just don't have the room to add any amps right now since my ht is also my living room. About 1 1/2 years ago I replaced my 46'' rptv with a 60'' lcd rptv and had to take out my component rack so all my gear has to fit in the T.V. stand and I don't have any where to move the rack that wouldn't require a major rewiring for the speakers and video cables.Although I'am sure your all right about separates being the way to go, until a can build a media room or the kid moves out i'am afraid i'll have to stick with the just a receiver for nowMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
If you know this is going to be your last power upgrade for a while, I would save up and go with a sunfire receiver. There is one for sell here for a $3200...
http://cls.audiogon.com/cgi-bin/cls.pl?miscrcvr&1135829573Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
well, its been a while since I posted this thread and I've just now gotten around to telling you guys what happened with whole upgrade thing, well what happen was I didn't get the denon or the svs because guess what .... the new x-box came out and my son felt like he just might die if he didn't get one, so we had to drop about $600 on that thing ( x-box, extra controller,and a few games) but I haven't lost the fever yet now I'am looking at the Denon 3805 instead of the 3806 as far as I can tell they are the same accept the 3806 has some hdmi inputs and outputs and I've found several on the internet for around $750 shipped so maybe after the holidays I'll be able to puts some more money towards the DenonCasey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
I say go separates also. That would definitely give you a tangible improvement. Then the SVS.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
HT processing, well, the Denon gets great reviews, but the Onks do an excellent processing job for HT. The most important speaker in the HT is the sub, it has the most work to do. I would buy the best one your budget will allow. I know little about subs beyond that so if the SVS is better than yours I think this is where you should put the dough.
