A question for you audiophile mathmaticans
aaharvel
aaharvel Posts: 4,489
edited November 2005 in Electronics
Double the wattage is a +3db. difference, correct?
i'm just wondering since my 5300 amp is 80x2, powering my stereo pair,
and my 7300 amp is 60x5, powering my center and 4surrounds~ should I go ahead and increase the center and 4surrounds to +1 in the pre-amp?
spl is pretty close, but JUST in the sweetspot is not realistic. SHould I just use the numerical formula?
the difference between 80watts and 60watts is 20.
20watts is 1/3 the amount of the lesser 60.
1/3 of +3 = +1 (so +1 for the center and 4surrounds) ? ??
ok i've gone crosseyed... :rolleyes:
H/K Signature 2.1+235
Jungson MagicBoat II
Revel Performa M-20
Velodyne cht-10 sub
Rega P1 Turntable
"People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
Post edited by aaharvel on
  • hoosier21
    hoosier21 Posts: 4,420
    Your thinking too much, you should set it up with a spl meter and the test tones in the pre/pro.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • aaharvel
    i like to think damnit! :cool:
    seriously the only reason i'm doing this is b/c basing the system JUST on test tones is pretty much useless if you're ever sitting outside the sweet spot AND if your amps aren't equal in power.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • PolkThug
    PolkThug Posts: 7,532
    Take measurements from different seats, then tweak away til you find a good average for everybody.
  • mantis
    mantis Posts: 17,561
    There is no way to exaclty adjust for the difference in power. What I have experienced when having 2 different amps driving a theater system is difference in dynamic range. When things happen onscreen, the lesser dynamic amp doesn't keep up with the other. This can be a huge problem depending on the person listening.
    I just left a customers house hwo also is having this very same thing. He is trying to use his receiver to power his center channel and rears and allowing his mains to be powered off a 2 channel amp. What a huge difference when things happen. The center channel gets drowned out . The mains jump out and bite you in the face while the center gets lost in the mix. Then when it's just time to talk and mellow out on the screen , the center channel is to low. You have to turn the volume up to a comfortable level so you can hear what the hell people are saying. When dynamic range kicks in , it's way to loud.
    My suggestion was to get a 5 channel amp so this problem will go away. He likes his receiver as a preamp (Denon avr3806) so going pre and amp is out of the question untill he trys it.
    I feel this is what you should do. Stop hurting your mind and put the pressure on your wallet. You'll be much happier without the money and with a system you can fully enjoy.
    Dan
    Dan
  • aaharvel
    thanks Mantis. Although the lesser Adcom doesn't get drowned out, since this is different than comparing receiver vs. sep. amp~ i was just trying to maximize my setup with something that I might be unaware of. But that's a good post, and thanks for the advice.
    BY THE WAY MY DESK CHAIR AIR PUMP JUST BROKE. KARMA FOR STARTING SUCH A STUPIDASS POST? hmm... :rolleyes:
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • John K.
    John K. Posts: 822
    Andrew, the maximum power rating of an amplifier, regardless of whether it's 60 watts or 600 watts, makes no difference in what you're trying to do. Yes, doubling amplifier power would allow a peak to be played 3dB louder(but you may have the misimpression that the more powerful amp is always louder). At comfortably loud average listening levels most speakers use about 1 watt. Depending on factors such as dynamics of the material, room size, listener distance etc., brief peaks might require 50, 100 or even more watts for a split second. The difference between the 60 watts and 80 watts which you mention is 1.25dB at peaks, but again this has no significance at the usual lower levels. Different amps can have different gain and have to be set differently to output the same power and different speakers with different sensitivities can require different power to play at the same loudness level, but difference in maximum power output is meaningless in regard to balancing the speakers. As was suggested, you should use a SPL meter to balance the outputs of your various speakers.
  • aaharvel
    thanks John K. I'm just leaving everything as it was. 0db. for all speakers, and balanced with the SPL meter. I've changed nothing, this thread i've started is retarded, and my chair is STILL fubared!
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • McLoki
    McLoki Posts: 5,231
    I was running the front stage through my Cinepro and my rear speakers through my Onkyo amp. to match the levels with an spl meter I had to set my front speakers -1db with the rears at +4.
    Since I got my amp fixed (only 4 channels were working - now 6 are working) all levels are set to -1db to be at reference level.
    I am not sure if it was the more powerful amp in the front channels or the additional sensitivity of the amplifier inputs. (probably a combination of the two) Anyway - as others have mentioned, just set all channels with an spl meter and don't worry about it.
    Michael
    heiney9 Posts: 25,497
    mantis wrote:
    There is no way to exaclty adjust for the difference in power. What I have experienced when having 2 different amps driving a theater system is difference in dynamic range. When things happen onscreen, the lesser dynamic amp doesn't keep up with the other. This can be a huge problem depending on the person listening.Dan
    This is certainly true for amplification that may be substantially different. In this case the Adcoms are very similiar units in build and parts. I would think in this particuliar case tweaking would be the best remedy. Certainly at the limit the lesser powered amp might begin to audibley (sp) falter before the higher powered amp but in normal listening tweaking to get the right mix is the best solution. Unless you're just looking for an excuse to spend money :p .
    Now if you had multiple amps from diff manufacturers, or a gross diff in output or design then moving to a 5-ch amp is one way to go.
    YMMV
  • shiu
    shiu Posts: 169
    If you want to calculate power gain/loss in dB, you can use the formula, gain in dB=10*log(P2/P1), 10*log(80/60)=1.25. Most calculators have the log (to the base of 10) function key. Of course this forumla is irrelevant to what you are trying to do but you know that already.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    AAharvel,
    Balancing with SPL is correct. Some amps come with controls to help your situation like say B&K for one. When using diff manufacture's the slew rates and impedences are likely different which can cause problems.
