350z+MMC6500=HELP
ulownz
ulownz Posts: 2
edited November 2005 in Troubleshooting
So I brought my practically new 2005 350z over to Hi-Fi buys. They say they can't install my MMC6500's and don't know how to due to the depth of the magnet. Can anyone here link me or post specific directions how this is accomplished considering that a large portion of the modded cars I see have this same component system and there doors look non-modified.
Thanks...
-Ryan
Post edited by ulownz on
    F1nut Posts: 50,841
    You'll get more help over in the Car Audio section.
  • Eric W
    Eric W Posts: 556
    Hi, the MMC6500 can be installed into a 350Z, however you need to make a spacer that pushes the driver forwards in order to clear the window glass. We have found an angled spacer would work the best and there is plenty of room to push the speaker "forwards". Also you will need to remove the magnet cover to install the speakers in there, but it has been done. :D
    -Eric
    -Polk Audio
