Lost OEM Remote, help!
fab5valentine
fab5valentine Posts: 84
edited November 2005 in Troubleshooting
My kids got to the OEM remote for my Denon 2802 (gone), and this is my only way into speaker set-up etc.. Do I have to buy a new OEM remote, or are there remotes like Harmony.. that can also access the set-up code for me?
fab5valentine
-fab5
Klipsch RB81's/RC62/RS52's
SVS PB12+/2
Denon 3808CI
Panasonic BD60
Toshiba 56MX195 1080p
Post edited by fab5valentine on
  • Willow
    Willow Posts: 11,075
    I saygo Harmony and don't look back. I just bought one and can't say anything bad, some kinks I must work out, but it kicks major butt
  • fab5valentine
    Hey, thanks for the reply.. Can I get into my AVR's set-up mode is the real question.. I'll call Denon today and ask some questions there too. What model of Harmony do you like or recommend? Thnx!
    fab5valentine
    -fab5
    SVS PB12+/2
    Denon 3808CI
    Panasonic BD60
  • Ricardo
    Ricardo Posts: 10,636
    I have the 659 and I can get into set up in my Denon 3803; I would say any Harmony will do it; mine is the cheapest (I think) and I have absolutely no complaints. BUT...you must know that for complex set up sequences you will need to spend some time assigning the functions to your remote, and then keep them documented to avoid forgetting them (i.e. Did I set the "test tone" to this or that button?)
    Good luck.
    SOPA
  • cmy330go
    cmy330go Posts: 2,341
    Should you decide that you want the OEM remote it is available at www.atvpartsearch.com part number 3990757004
    Everyone here is right. Harmony does make a good universal, and there is a good chance you will be able to get into the setup menu with it. However I am a big believer in having the OEM remote in the event I ever want to sell a component.
    Good luck with the search!
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • fab5valentine
    That is perfect advice! I hadn't thought of that.. I bought the AVR to have for a long time.., yet we all get that *bug* to upgrade huh? Harmony looks like a fantastic product! Thanks!
    -fab5
    SVS PB12+/2
    Denon 3808CI
    Panasonic BD60
  • beardog03
    beardog03 Posts: 5,550
    Thanks for the linky..
    could come in handy..!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Willow
    I bought the 659 as well, you may try ebay to see if someone is selling just a remote for you receiver.
