yamaha rx-v2500
snakebitten
snakebitten Posts: 94
edited November 2005 in Troubleshooting
I had the yam in to fix a broken optical jack. When I hooked it back up, no sound. On the front panel the straight/effect blinks as do some other lights and it gets stuck on staight mode.(locks up) Any ideas?
Post edited by snakebitten on
  • SuperDave
    SuperDave Posts: 168
    you could hook up to another available jack to see if it is the connection or the receiver, if you have a coax or rca cable to spare, in either case it probably needs a return to the shop
    SuperDave
    Yamaha RX-V992 (Center,Rears)
    Adcom GFA-5500 (Mains)
    Denon DVD-1920
    Mitsubishi 40" LCD
    DirecTV DVR Whole House
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
  • cmy330go
    cmy330go Posts: 2,341
    I had a similar problem once that required I reset the receiver. Below is a link with instructions on how to reset the rx-v2400. As I recall the steps are the same for the 2500. Hope this helps!
    http://www.yamaha.com/yec/customer/presets/preset_RX-V2400.pdf
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • snakebitten
    thanks. Yes it helped. still no sound. I will try hooking the speakers direct (no amps) to see if i get sound.
  • snakebitten
    I hooked the front speakers direct. The yame plays for 3 seconds then nothing. At least I know its not my amps now.(same as with amps) Guess I call the stereo store tomorrow.
  • cmy330go
    Does it shut off after 3 seconds or does the sound just quit?
    HT
    2 CH
  • snakebitten
    the sound quits. unit stays on.
  • cmy330go
    Then I would definitely say a service call is in order. :(
    HT
    2 CH
  • snakebitten
    ya, I think so. Guess I head down there now.
  • snakebitten
    They are going to replace the yame with a new one. Thanks for the posts and the link.
  • cmy330go
    Sweet! And you're welcome. Hope the new one works out for ya.
    HT
    2 CH
