RM6750 subwoofer connection
JEM2114
JEM2114 Posts: 5
edited October 2005 in Troubleshooting
I have a receiver (Yamaha) with a subwoofer RCA output for bass management for all areas in 5.1, i.e. center, FL, FR. The subwoofer in theRM6750 package apparently has connections for FL and FR only and I can compensate for this by directing all bass management to the FL and FR speakers through menus on the receiver.
My question --- is there a way to use the subwoofer with the subwoofer output jack on the receiver?
Post edited by JEM2114 on
  • Eric W
    Eric W Posts: 556
    edited October 2005
    Yes. Connect all the satellites directly to the receiver and then run a single RCA cord from the "sub out" of the receiver to either L or R line in on the subwoofer. Turn the "low pass" knob as high as it will go clockwise. On the receiver, in the set up menu, set the "crossover frequency" to "120 Hz" and all the speakers to "small" and subwoofer to "yes".
    This will allow you to use the subwoofer output jack.
    -Eric
    -Polk Audio
