Pioneer VSX-1015TX or Denon Avr-3805
jack7777
jack7777 Posts: 38
edited October 2005 in Electronics
I was thinking about picking up a denon AVR-3805 to power my rt55is(4), but I seen this at bestbuys. The Pioneer VSX-1015TX sales pitch. It's simple: our top-of-the-line VSX-1015TX dishes out intensely great home theater performance. It's the world's first receiver to process THX Select 2, for high-impact, multi-channel audio for cinema, concerts, and gaming in rooms of up to 2,000 square feet. It also features advanced surround processing, with DTS-ES Discrete, DTS 96/24, Dolby Digital EX, and Dolby Pro Logic IIx decoding. Pioneer's Digital Core Engine performs all digital signal processing with one powerful, compact circuit board, for a shorter signal path and less radiation. A double-precision, high-speed (180 MIPS) Motorola 48-bit DSP the same chip used in Dolby and DTS theater systems worldwide delivers a super-accurate PLL sound-processing clocking module, very low jitter, and virtually no audio degradation. The VSX-1015TX sends 120 watts of equal power to all seven channels. Advanced Direct Energy MOSFET discrete transistor amplifiers offer high-power drivability, ultra-efficient amplification, stable imaging, extremely low energy loss, and ultra linear ouput to all channels. And with Automatic MCACC, the VSX-1015TX actually measures and calibrates your audio system for sonic perfection specifically for your living room, regardless of shape or size, automatically. With Microsoft, Pioneer co-developed a Windows Media Audio 9 (WMA-9) Professional Decoder, allowing you to listen to two-channel and multi-channel WMA compressed audio files. Plus, Video Conversion up-converts S-Video and composite video into component video, for a simpler, higher-quality video connection to your TV or Panel. Included are a full complement of connections (with a digital optical output) and a new LCD remote. Power Amplifier Design: Advanced Direct Energy MOSFET Surround Power: 840 Watts Total System Power - 120 watts x 7 (20 Hz - 20kHz .2 THD @ 8 Ohm) Stereo Power: 240 Watts Total Stereo Power - 120 watts x 2 (20 Hz - 20kHz .2 THD @ 8 Ohm) Digital Decoding & Processing Digital Engine: Double Precision 48-Bit Motorola THX: Select 2 Certificat What do you guys think? I know the denon is one of the highest quality products on the market, but is also 3X THE PRICE. Is it worth it? will the pioneer provide quality CLEAN sound??
Post edited by jack7777 on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited October 2005
    Bottom line: The Pioneer is a good value for the $$$.
    Bottom line: The Denon is a good value for the $$$.
    Other than the 4-55s, what speakers do you have and what is your room size?
  • fireshoes
    fireshoes Posts: 3,167
    edited October 2005
    You should be able to find some great closeout deals on the 3805 right now because the new model is on the market now.
  • jack7777
    jack7777 Posts: 38
    edited October 2005
    my room size is 13x17, and I am using 2 cs400 for front and rear centers. as far as price the pioneer is 400.00 and the the cheapest I can get a new denon is 800.00 authz. dealer.
  • mantis
    mantis Posts: 17,204
    edited October 2005
    Go with the Denon, it's a all around better receiver. Now if you take a look at the Pioneer Elite line, new ball game. The new 74 is killer.
    Dan
    Dan
  • izafar
    izafar Posts: 819
    edited October 2005
    I don’t want to Hijack the thread but I am also interested in VSX-1015TX, and want to replace my Denon AVR-2802 with this. I will only be using this Pre-Pro only as I use Carver multichanel Amp to drive my speakers, therefore I am not that much interested in the Amp section. I am interested in comments from some one experienced with latest line of Pioneer receivers from DAC/DSP engine perspective?
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • Mike682
    Mike682 Posts: 2,074
    edited October 2005
    There is a monster thread with lots of discussion about the Pioneer 1015x:
    http://www.avsforum.com/avs-vb/showthread.php?t=495693&highlight=1015
    Hope this helps
    Mike
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited October 2005
    I'd definitely go with the Denon over the Pioneer...
  • aaharvel
    aaharvel Posts: 4,489
    edited October 2005
    same here.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • shack
    shack Posts: 11,154
    edited October 2005
    Denon and the RT55is are a good match for each other IMO (at least mine are).
  • jack7777
    jack7777 Posts: 38
    edited October 2005
    Hope this helps
    Mike
    Thanks Mike that is a great thread.
