Lsi15 question
gright
gright Posts: 22
edited October 2005 in Speakers
:confused: Could someone who has the Lsi15 floor standing speakers tell me how high the lower connection posts are from the ground? I am running some speaker cable under the floor and I need to make sure I leave enough to reach the posts. I understand these speakers have both upper and lower connectors and can be hooked to cables in either location. I have the speakers ordered just don't have them yet. Thank you for any responses.
Help clean up the city, eat a pigeon.
Post edited by gright on
  • fireshoes
    fireshoes Posts: 3,167
    edited October 2005
    I don't have a tape measure handy, but I'd say they are probably about 6 or 7 inches up.
  • Normanality
    Normanality Posts: 297
    edited October 2005
    The height to the lower posts is 6" and 8" to the upper post.
    Best to leave a little extra for adjustments ;)
  • scottnbnj
    scottnbnj Posts: 709
    edited October 2005
    gright, are you sure you need to cut it that close before hearing them in that position? i mean, if there's only one place they can be, that's one thing, but if that's not the case, you'll probably do better to leave room to experiment with placement.
  • gright
    gright Posts: 22
    edited October 2005
    Thanks for the replies. I am not going to cut it close. I have decided to order more cable. I have one 30' piece of audioquest cv4 cable but it just isn't going to be long enough for both speakers. I would rather have too much cable than cut it off too short even though I realize for better sound shorter is preferred.
  • mantis
    mantis Posts: 17,559
    edited October 2005
    I listened to the cv4 and it's a great cable. Good luck with it
    Dan
    Dan
