psw10bk Wiring
sjpalombi
sjpalombi Posts: 1
I just purchased a psw10bk, it doesn't have a LFE IN but does have a L & R input. The salesperson at the store said that i can split the preamp out on my reciever and it will work fine. Is this true? :confused::(
Post edited by sjpalombi on
  • nellis8166
    nellis8166 Posts: 292
    edited October 2005
    Just to a y splitter and a single subwoofer cable.
    RTi10
    CSi5
    RTi28
    SVS PB12-ISD2
    Denon 2106(pre/pro)
    Adcom 5503(200x3)
    Audioquest Diamondback ICS
    Kimber Kable 8tc biwire(mains and center)
    "Don't let your silly dreams fall in between the crack of the bed and the wall."
    -J. James
  • mantis
    mantis Posts: 17,563
    edited October 2005
    hook up left or right and need not the y splitter. It will work fine this way.
    Dan
    Dan
  • nellis8166
    edited October 2005
    Dan's way will work fine too...I think it just increases your output a few db's if you use a y splitter.
    RTi10
    CSi5
    RTi28
    SVS PB12-ISD2
    Denon 2106(pre/pro)
    Adcom 5503(200x3)
    -J. James
  • John K.
    John K. Posts: 822
    edited October 2005
    SJ, welcome. As the previous replies indicate, either one or both of the inputs can be connected(they join inside the sub). Since the sub output on most receivers has enough output even when feeding just one of the sub's inputs, try that first, as Dan suggested. One further suggestion, since there's no LFE input to bypass the sub's internal crossover, turn the control all the way up to 200Hz to get it as far out of the way as possible of the crossover which your receiver will be handling.
