new to forum, couple of easy questions
NVR2LOW
edited October 2005 in Speakers
hey guys, i have a few questions...i am currently looking to build a home theater system piece by piece...i am limited with funds due to college...lol..im am looking at an onkyo 503, rti-8s or rti-6s to begin with...them later on get a csi-3 with some type of rears just not sure yet...i havent decided if it was worth the 100 rti6 or the 180 rti8...not sure if the difference between the two is sufficient enough to justify the price difference...im leaning toward the 8's though..i love the look of both of them..any comments on the above setup? any help or advice would be greatly appreciated!
drew
  • AsSiMiLaTeD
    edited September 2005
    if you're not going to add a sub, I'd get the 8s. If you're going to add a sub, you'll be fine with the 6s
  • BIZILL
    i can attest to this. not much difference without a sub. even less difference with sub. if i could start all over, i'd get rti6's all around and save a few hundred dollars. but if money is not an issue, then obviously the 8's.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • aaharvel
    i would think the 6's with a sub would sound better than the 8's without, especially driven off of a receiver only, no separate amplifiers. jmo. I don't own the 8's myself, but i have listened to them without a sub, albeit in Circuit City's 'State Of The Art' listening area. :rolleyes:
    welcome to the forum! :)
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Spawndn72
    Not much more to add, but just wanted to say welcome Drew. Hang around there is alot to learn.
    Setup:
    Adcom GFA-545 amp
    Nad 1600 pre
    Dual 704 TT
    Pioneer 707 R2R
    Pioneer DV-578A Multi-format
    Polk SDA-2 Mains
  • Schris22
    howdy as well.
    Don't have too much personal experience on the Rti department but i am in college!
    My college system is listed below somewhere...make sure to watch the bass anyway if you live in a dorm /small apt.
    Not sure if it's my big heavy concrete block under my sub but no one complains about me....just my suitemates who are using small computer speakers...
    if you're looking for a cheap sub a lot have used the one I have and been very please (I am one of them)
    Also depending on your room, too small can be bad for certain speakers...so hopefully where you get them will have a return policy (maybe certain spots on ebay)...dorm rooms are small =(
    Chris
    Receiver: Onkyo TX-SR502-S
    DVD Player: Pioneer DV-578A-S
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
    Subwoofer: 10'' Dayton 100 Watt
  • janmike
    I wish I had a stereo when I was in school.
    Michael ;)
    NORTH of 60°
  • NVR2LOW
    haha, yea i think ive decided on getting the 503 for sure, the rti6's and the psw10 sub i think it is..then later on ill grab the rti8's and move the 6's to the rear..when funds allow of course..is the csi3 a good center to go with the rti6's and 8's ? :confused: i cant afford the csi5 :( ...ill just be running the 6's and the sub for awhile tho...thanks for all ur input
  • halo
    Sounds like a solid plan & WELCOME to the forum! :D
  • Schris22
    503 eh....i got the 502 from fry's what price are ya looking at....I'm soooo money tight right now....*stupid audio electronics*....just kidding *runs to hug speakers...
    seriously, well if you can't afford the csi5 then just go for the csi5...some will say save up until your satisfied with what you can get. Well my advice is don't listen to nicer speakers. RTi's are very fine for movies.
    I see your building your system piece by piece. Just make sure not to cheap out on speaker wire. And at least some "decent" (subjective word I know) interconnects.
    If your focus is Home theater I would get a sub really soon, and though a lot of people in this polk forum are very polk happy (obviously) a lot of them will support SVS and HSU and think that polks sub aren't that great. I would go with the sub I have or an Advent sub has popped up as an alternative.
    Chris
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
  • michael_w
    edited October 2005
    A big question you need to ask yourself before buying anything is if you listen to movies more than music. I noticed you said home theater system but just to clarify. You can build a much much better sounding 2 ch system with a certain amount of money than if you had to build a full ht system with that same amount of cash. If you are not so much into movies I suggest you try going without a sub for a while. Pure 2 ch audio with no sub can be quite nice, plus you save money because you didn't have to buy a sub. My advice on getting a psw10 would be to just save your money and do without. The RTi4's, 6's or 8's should do great things if placed properly.
