oily film in tweeter
Aqs612scag
I was wondering if this is a problem.
They are sl2500's one of them seems to be coated all the way through leaving a shiny appearance and the other one appears to be coated halfway. I detect nothing different with the sound so I dont know what to make of this other than the way it looks. Should I have these replaced or not?
thanks
Alex
thanks
Alex
Post edited by Aqs612scag on
is ferofluid leaking out?ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
The replacement tweeter to use should you need to replace, is the RD0194-1. I have heard they are a better replacement than the originals.
I took a picture and what you can see is that the coating is from the top to the sides forming an inverted U shape. The other tweeter is completely coated.
