Help! Amp sounding strange
jbonecpa
jbonecpa Posts: 1
edited September 2005 in Troubleshooting
I have a 12 channel amp powering 6 pairs of speakers along with 6 impedance matching volume controls throughout the house. When I connect one particular pair of speakers they are distorted and only play at a very low volume. If I put my ear to the amp I can hear a distorted audio signal which is alarming because the amp doesn't have any internal speakers to be outputing any sound. I get the same result no matter which channel I connect this particular set of speakers to so it must have something to do with the wiring for these speakers. All the other speakers sound fine.
Would this be a short in the wiring??? Or something else????
Post edited by jbonecpa on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I would say a DEAD short on the speaker wiring or speaker.
    If you have meter see if short is removed when speaker is disconnected or not. If it does then the speaker is the problem, if not it's the wiring.
    Don't hook this back up you could damage the amp. Fix the wire / short.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
