Lsi and Rti in the same time?
Tequila
Tequila Posts: 104
edited September 2005 in Speakers
Lsi 25 for fronts and Rti8 for surround..., yes i Know, the Lsi series has 4 ohms, and the Rti is 8 ohms...Is right play together?
Thank you so much.
Post edited by Tequila on
  • gregure
    gregure Posts: 871
    While surrounds aren't as important as fronts, I think you will notice a severe difference in sound quality between the front stage and the rear, as the two lines have completely different types of drivers. While it is better to run 4 Ohms in the front only with a lesser receiver, if you have the proper amplification (and budget) for LSi all around, it would be better. Still, as with most of us, you can upgrade in stages. Try it out with the 8's. If it doesn't bother you too much, you can upgrade the rears later on.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
  • mantis
    mantis Posts: 17,322
    No,
    as noted above, i'll add that I personally wouldn't mix speakers as well as speakers with different ohm loads unless you have a really good amp that can play nice in this setup. Then the tone factor comes in and I wouldn't do it.
    Dan
    Dan
