Speaker Wires ~ I'm a believer!
Holydoc
Holydoc Posts: 1,048
To tell you the truth, some advice I take as the gospel and some I take with a grain of salt. I am sorry to say that I was taking the recommendations for sturdy speaker wire with a grain of salt. Well you can't always be right. :o
However, I noticed that one of my FXi3's did not seem to match timbre with my other Polks. My first thought was that the placement was making it sound a bit different. When that didn't change anything, I immediately blamed it on my hearing thinking that the back speakers might not sound the same as the others to my ears. Finally I just got a wild hair and decided to check what could be different. Then I remembered. That was the only speaker whose wire runs through the ceiling and the only one that I had someone else install.
What I discovered when I examined the speaker wire running through the ceiling was that it was about the size of a thin piece of yarn. I had never seen a wire so skinny!
So at 92 degrees in the shade (must of been boiling in the attic), I Lugged my reluctant body up to the attic and replaced the dental floss cable with Monster Cable that I had a large spool of. Cursing, sweating, and itchy from insulation, I eventually was able to turn my stereo back on.
What a difference! Not only does the timbre match perfectly, but everything just seems to sound better. I know...I know... One speaker wire doesn't make everything sound better, but to me, all is good in the world. :D
So there you have it. A testimonial from a true novice. Cable does change the sound.
I'm a believer!! Thanks again for giving me the knowledge to even check that area.
Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote
Post edited by Holydoc on
«13
  • beardog03
    beardog03 Posts: 5,550
    edited September 2005
    next stop...
    cable swap program... :D
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
    F1nut Posts: 51,776
    Ok, now that you're a believer it's time to upgrade from the "M" stuff and don't forget the interconnects, very, very important.
  • Holydoc
    Shhhhhh.... you guys are making me poorer and poorer!
    I keep telling myself, "do not get addicted...do NOT get addicted"
  • beardog03
    Too late..!!
    try going from the "M" stuff, to the "other " "M" stuff..(MIt)..!!
    once you open the gates and hear what you have been missing...there`s no going back..!!
    actually, a good place to start is Signal Cable....IMHO
    www.signalcable.com
    good cable...good prices
    (mention your a forum member and get a discount)
    I believe it`s 5%
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • cfrizz
    cfrizz Posts: 13,415
    I know most of us dislike M, but it is more for business practices rather than the fact that they make a bad product. Expensive yes, but bad not really.
    Holydoc already had the stuff & he used it. It made a big difference & he is happy with it. There is no need of him spending more money, when he already got the results he was hoping for.
    So enjoy your system Holydoc!
  • unc2701
    unc2701 Posts: 3,587
    Congrats on the upgrade!
    Although, I would like to point out that just about everyone agrees that 16 ga+ and long runs definitely hurt your sound :)
    Backburner:Krell KAV-300i
  • Holydoc
    Unc2701,
    Probably a dumb question but does Monster cable only come in one size so that is how you know what gauge I used? Personally, I have no idea what gauge it is. I just know that it made a world of difference compared to the "dental floss" that I had already there. It was very flexible and extremely well insulated. The only two complaints that I had was that
    1) it had a plastic center running through the wires, that I could only assume was there for stiffness.
    2) The twist-on Monster cable banana clips that I had purchased separately seemed to be too large to accommodate the cable size (I placed on Radio Shack crimp clips instead)
    Though I do not currently have the cable in front of me, I believe the one I purchased was the "Monster XP® Navajo White - Compact Speaker Cable ".
    Thanks for all the input guys!
  • steveinaz
    steveinaz Posts: 19,545
    RUN.....RUN as fast as you can. LOL!!!
  • unc2701
    16ga+ was referring to the "dental floss"... I don't think monster makes anything smaller than 16ga (anyone know different?)
    Anyhow, with the whole "do speaker cables matter?" debate, almost everyone can tell a difference between cables smaller than 16ga vs larger than 16ga, especially with long runs (like you'd have to your surrounds). The debate really kicks in when you talk about all these exotic, short run, very expensive cables vs an equivalent guage of a cheap cable.
    Back on topic- it sucks that installers put in such crappy cable, when it's so widely accepted that you just can't push high wattage through them- in fact, in some areas that's against code.
  • PolkThug
    PolkThug Posts: 7,532
    Yep, simple case of the skinny wire giving too much resistance over that long run.
    When your wire gets around 30ft, you need at least 16awg. I'm guessing you had something like 22awg.
  • McLoki
    McLoki Posts: 5,231
    That is one of those business practices things that people were talking about earlier. Monster does not advertise the gauge of their wire. (similar to Bose not advertising the specs of their speakers) - (BTW - I think the monster cable you have is 16 guage).
    Gauge is a measure of how thick the wire is. The smaller the guage the thicker the wire. -3 gauge is twice as thick. (16gauge -3guage = 13gauge so 13guage is twice as thick as 16guage....)
    The main thing you have to worry about with speaker wire is resistance and the thicker the wire, the less resistance it has. Many people are of the belief that as long as you are at 14-16ga. you are fine for most distances.
    You can get 12guage wire pretty cheap at most home improvement stores or from Blue Jeans Cable (or other internet stores) so if you are purchasing new, I would get 12guage and not worry about it. (I would expect you can get generic 12ga. cheaper than you could get 16ga. monster cable)
    Just my thoughts. - If you are loving the way your system sounds now - enjoy it. When you get a wild hair and want to try a cheap upgrade, get some generic 12ga. wire (or even 10ga.) and see if you can hear a difference with it. I would suspect starting with 16ga wire that you will get more of a bang for your buck by getting better interconnect cables than upgrading your speaker wire though.
    Michael
    F1nut Posts: 51,776
    Although I disagree that it's just about the gauge size because it's not! I do believe that for the level of gear and purpose of use concerning Holydoc's set up, he's probably fine where he's at. However, I do think that he should at least try the Cable Swap Program for interconnects as they do make the biggest difference.
  • PolkThug
    Just don't try to measure the differences. They can only be detected by the magnificant human brain. :p
  • Polkersince85
    Polkersince85 Posts: 2,883
    I'm making a custom set using 10ga. 105 strand silver-plated wire. Will be driving SDA SRS2. Stay tuned.
  • Holydoc
    F1nut,
    I am flattered by your suggestion that I join the Cable Swap Program, but I feel it will be too self-serving. I have not done this enough to have built up the "acoustical ear" that you experts have. You guys are able to listen to a system and determine if it is musical or not. The only thing I would be able to do is tell you whether a certain cable sounded better on my particular system to my particular ears. Heck I cannot even tell you if one system sounds warm or tight as compared to another. All I know is what sounds best to me. That sort of review is only beneficial if you have my system, placed in my room, with me listening to it. That would be a huge diservice to this forum.
    No, I think I will let the experts poke and prod this project to determine what is the best route to go. I will then reap the benefits of your decisions as you guys have yet to let me down. Maybe in a couple years, I can return the favor for some other newbie like myself.
    /salute
  • Willow
    Willow Posts: 11,231
    Holydoc wrote:
    F1nut,
    Heck I cannot even tell you if one system . All I know is what sounds best to me. /salute
    That's all that matters. What F1 is suggesting (F1 correct me if I'm wrong) is try some different cables, a big selection which can be found in the cable swap. Try one, two, many all of them. If you think it makes your system sound better great if not great. You may be surprised in your findings. I have yet to join the cable swap, but have tried a couple different ones.
  • McLoki
    McLoki Posts: 5,231
    That is the point of the cable swap program. For the cost of shipping a few cables, you can test a number of cables (some very expensive) and determine for yourself if you like the sound of them with your gear.
    It ultimately doesn't matter what I or anyone else thinks of your system. You listen to it and you pay for it, so for your system, your opinion is all that really counts.
    Michael
  • bknauss
    bknauss Posts: 1,441
    I don't think anyone on either side of the cable camp would disagree that having 16 ga speaker wire, especially for long runs, is a bad idea.
    Now start debating on which well made speaker wires/interconnects sound better, and you'll have a fight on your hands :)
    Brian Knauss
    ex-Electrical Engineer for Polk
  • mantis
    mantis Posts: 17,394
    Depending on system level, Monster cable is or not so good. Monstercable is fine for most lower to mid end systems. For theater , Monster is fine.
    Music however is where Mnster in my opnion fails or comes up short. I feel there cables lack mid range clarity. They provide plenty of bass and uncontroled highs.
    I grew out of Monster many years ago. It's a learning curve that most of us go threw.
    You can however stay with monster and get good results.
    Remember like anything in the system, it's up to the end user if the product is good enough or needs improvement. Some people actually love monstercable and there is nothing wrong with that.
    I don't think it's right to bash Monstercable. It's not for all systems but it has good results in others.
    Dan
    Dan
    F1nut Posts: 51,776
    Bingo!!!
  • ode
    ode Posts: 58
    So then why do some other purists swear by BNC cable, which is relatively thin? Is it the shielding?
    F1nut Posts: 51,776
    Maybe because they don't know what they are talking about.
  • cfrizz
    Ode, I think you are talking about BJC (Blue Jeans Cable).
    I am not a purist by any stretch of the imagination. I just know that thier interconnects sound much better than the stuff in the box that comes with the electronics.
    It's well made and it doesn't cost an arm or a leg, which suits me just fine.
  • emcclary
    emcclary Posts: 29
    I felt I had to jump in on this one. I have been fiddling with stereo equipment for the better part of thirty years and I have had all kinds of cables over the years. Good cabling is a matter of low resistance, good conductivity and excellent shielding. You would be amazed at the markups involved in so called esoteric cables that purport to bring out the rough edge of the violinists fingernail across the string. Almost all claims made take place outside the range of human hearing so why pay the money for improvements that can only be seen on a high end testing equipment. Unless you are going to use pure silver or gold wiring all type 101-102 OFHC copper of same gauges are the same. I can say this because I run a metal manufacturing company the sells these materials to several high end audio cable companies who shall remain nameless. Stick with 14 gauge and up OFHC copper stranded wire with good connectors that will not oxidize and you will be fine in 99.99% of the cases.
    HT Setup
    Rec B&k AVR307 w/updated software and hardware
    DVD Sony DVP S9000ES
    VCR JVC SVHS HR-S3600U
    CD Nakamichi MB3S
    2 Monster HTS3600
    Sony KF-60XBR800 LCD Proj
    Mains Def Tech BP7004
    CLR Def Tech 2500
    Sides Def Tech UIW BPZ/A
    Rears Def Tech BPVX
    Sub Def Tech Supercube 1
    Outdoor System
    Rec Sony STR DE197 (2 Chan)
    Cd Nakamichi MB3S CD (Yes I have two of them)
    Speakers Paradigm Stylus 350's
  • Tritonman
    Tritonman Posts: 159
    Michael
    Great post! Its good to "hear" someone with that kind of attitude on Audio forums.
  • Holydoc
    EMCClary,
    Thanks for the advice. The problem that I probably had was that I had "dental floss" running to my furthest speaker as compared to quality cables to my other speakers. Even with my untrained ears, you could hear a "thin forced" sound coming from that speaker with the bad wiring. I would place the stereo test tones and the tone coming from that speaker was significantly different than the others.
    Now with the new wiring, I can close my eyes (with the exception of the subwoofer) and cannot tell a difference in sound from one speaker to the next. It just sounds like you have taken a single speaker and have moved it to different locations around the room keeping the same distance from my head.
    That is what I consider a well balanced system! :)
    For you purists out there, I did order the Avia stereo tuning system from SVS to be sent along with my PB12-Plus. When my subwoofer arrives, I will ensure that everything is tuned to the best of this "newbies" abilities.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    OK, So Jesse / F1Nut say's ok upgrade the "M" stuff so who else makes in-wall cables?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • McLoki
    McLoki Posts: 5,231
    Blue Jeans Cable 12 white is cl3r (in wall) and 10 white is cl2 (plenum grade). Cost is .39 and .57 / foot.
    The actual cable is Belden 5000 series; the 10-gauge 5T00UP and the 12-gauge 5000UE
    I am currently running the 10 ga. cable and it sounds great. (running through a fireplace plenum)
    Michael
  • shack
    shack Posts: 11,154
    Ah...another cable skeptic. Nothing new here that some haven't already said. What is the name of your company and what are the companies that you sell to? Without that information it is nothing more than heresay. I can sell eggs, butter, flour, etc... to 5 different people and the 5 cakes they make will probably all be different. Same with raw materials. The end result is what matters...not what they start with.
    Some claim to be able to tell the difference between cables. I believe they can. Others don't. There are many here that believe as you and many that do not. The markups, voodoo claims, testing, ears vs machines have all been discussed adnausium. Several "white knights" have come through informing us of the error of our ears and the falacy of our preconceived desire to hear a differece in wire and cables. Rather than blindly listen to the proponents or nay-sayers, we have a cable swap program here at the forum with various speaker cables, interconnects, and power cords from inexpensive to relatively high dollar. Costs almost nothing to check them out and form one's own opinion. Anyone that takes YOUR advice or MY advice when they have an opportunity to form their own opinion...are (as Micah Cohen would say) nothing more than sheeple.
    I notice you are relatively new here. Welcome. Knowledgable people are always a plus to the fourm. Your 30 years experience with hifi is more than many...less than others. Discussion is great...opinions are too... Hang around, share your thoughts and expeience....just don't lecture or preach.
  • Holydoc
    Oh my. I have been reduced from a "Newbie at Home Theatre" to a "Sheeple"!
