Yamaha RX-V757?
tdogroeder
tdogroeder Posts: 53
edited September 2005 in Electronics
I have RTi6's for front speakers and PSW303 for my sub, should I keep the crossover set at 80hrz? And should I have the speakers set at small or large on the reciever? Or what is the best setting to optimize my Rti6's and get the most out of my sub?
Yamaha RXV-757
JM-Lab Focal Cobalt 816 S's, JM-LabFocal Cobalt CC 800 S, FXi3's, RT15's & PSW 303
Post edited by tdogroeder on
  • John K.
    John K. Posts: 822
    TD, yes, 80Hz probably would probably be the best setting for the crossover in your 757. 80Hz is a good compromise, being high enough to take a significant amount of the low bass load off your speakers and the receiver amps while not being so high as to make the sub easily localizable. So, set all speakers small and use the LFE input in your 303 to bypass its internal crossover, since the 757 is handling the crossover duties.
  • tdogroeder
    That is what I have my settings at now. So I should have gotten the RTi4's instead of the RTi6's, I would have saved a lot of money with about the same sound.
    Yamaha RXV-757
  • mantis
    mantis Posts: 17,327
    Thats only for you to judge. They both are fine speakers. They however do sound slighty different. they sound the same in many ways.
    Dan
    Dan
  • fireshoes
    fireshoes Posts: 3,167
    When your crossover is set at 80hz, it is not a hard wall. Bass below the crossover point begins going to the subwoofer, but some also plays through the speakers.
